another way, undercar neons?
aznrico
Posted: November 29, 2006 at 12:30 PM / IP Logged
I recently bought an undercar neon kit and looked at the instructions. I was debating if I should actually install them or not, since I found out that the only way to mount them involves drilling holes. I am worried about the car rusting because of this installation method; can anyone suggest another way to mount these tubes without drilling? or to prevent rust under the car? I haven’t been successful in looking for other kits without screws.
ill-logix
Member - Posts: 39
Posted: November 29, 2006 at 1:29 PM / IP Logged
You can paint the hole with either an epoxy based spray paint Or use a galvanising zinc spray paint.  You can find the
ill-logix
Member - Posts: 39
Posted: November 29, 2006 at 1:32 PM / IP Logged
Sorry, bumped the send button.
You can find the zinc spray at a place that carries welding supplies.  You could also try ospho.
bballguy162006
Member - Posts: 21
Posted: December 06, 2006 at 3:27 PM / IP Logged
Mabye you could use JB Weld?  Although that would be permanent...
myzery
Posted: December 22, 2006 at 6:09 PM / IP Logged
You can also try...
After you've mounted the tubes to the underside of the car, tape off the tube where there is a screw near, and hit the area with some Rubberized Undercoating. It'll keep out moisture and prevent rust in the holes. And when you remove them, hose the holes again till they're completely covered.
justified07
Posted: January 03, 2007 at 2:13 AM / IP Logged
When you install the neons with the screws put some silicon on the screw before you put it to the undercar body so that when the screw goes in the metal its also got a sealent on the screw, you can get silicon at any parts store just ask for silicon glue it comes in a tube like what your toothpaste comes in, hope that helps.
jmendez452
Posted: January 09, 2007 at 11:29 PM / IP Logged
use wire tie rods
j mendez
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
