2005 grand cherokee remote start
tireman
Posted: December 05, 2006 at 8:33 AM / IP Logged
I just installed a Bulldog RS in an 05 Grand Cherokee. I hooked up the Accessory and 2nd starter like this: http://64.85.6.129/extrainfo/diagrams/26500_GRAND-CHEROKEE_CHRYSLERS%20STARTER%202%20AND%20ACCESSORY%20DIAGRAM.pdf">Relay diagram
Now when I shut the vehicle off It diesels until the fuel stops. There is not a crisp ignition stut down. This happens whether I use the sterter or the key to start it. I tried to disconnect the white wire on the 86 terminal on the acc relay and the problem goes away... except now I have no acc while running.
Any ideas??
Keep in mind I am a Newbie!
Hymer
Silver - Posts: 695
Posted: December 05, 2006 at 8:50 AM / IP Logged
you could try a 610 ohm instead of a 560 ohm.. It may need to seek 1k to ground at shutoff.. Call The resistances are probably out of tolerance.. recheck them
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
tireman
Posted: December 09, 2006 at 8:38 AM / IP Logged
Is it possible that I have the diode on the starter 2 relay going the wrong way?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 09, 2006 at 12:30 PM / IP Logged
It is poss. remember, a diode can "stop" both 12volts, AND ground....
tireman
Posted: January 05, 2007 at 4:53 PM / IP Logged
Just in case others may run into this -... I had to diode isolate the white wire on the acc realy.  Problem solved works perfect.  Thanks for the help.
