VSS on Servo Connector, 2000 Windstar
caramok
Posted: December 13, 2006 at 8:49 AM / IP Logged
installing ccs-100 cruise control on Windstar 2000 van. Found the 10 pin connector for the factory servo.
Really appreciate if someone could tell me which pin for VSS connection.  Mitchell shematic showed pin1 speed control (+) tan/org; pin 2 speed control (-)  pink/Ltblu.
Car Amok
shaggy12volt
Copper - Posts: 164
Posted: December 13, 2006 at 11:23 PM / IP Logged
vss is BLUE / YELLOW BLACK 2 PIN CONNECTOR LOCATED ON DRIVERS SIDE TRANS AXLE NEAR SHIFT LEVER if its not in the 10 pin harness.
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
caramok
Posted: December 16, 2006 at 9:24 AM / IP Logged
thanks Shagmaster for the pointer.
I tapped in the blue / YELLOW wire from the black 2 pin connector as you described but didn't see voltage increase when speeding up (stayed around 4 mv). Connected to the CCS-100 and no crusie.
will continue hunting for that litte wire...
Car Amok
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
