Aftermarket head unit for Scion xB
secured_auto
Member - Posts: 8
Posted: December 26, 2006 at 10:05 PM / IP Logged
I want to change original head-unit in my '06 xB.... wiring harness is the same as in all new toyota, but thing that bothers me is factory steering controls and auxiliary input..... I'm gonna use pioneer deh-p9600... Do I have to buy any additinal parts for that?
Thanks in advance....
Mike
rudydapimp
Copper - Posts: 390
Posted: December 27, 2006 at 1:01 PM / IP Logged
yes, you can get the steering wheel contorls back, and it will cost you a little more. Pac-audio.com has the pioneer interface as well as a universal interface to retain steering wheel controls.
secured_auto
Member - Posts: 8
Posted: December 28, 2006 at 12:40 AM / IP Logged
ok. I already got that, so only problem now is aux input in the dash. Is there any way I can make it work too????
geepherder
Platinum - Posts: 3,668
Posted: December 28, 2006 at 6:47 AM / IP Logged
The new deck will likely have one of it's own you can use. I'm not sure what this factory aux-in looks like, but you may be able to either wire into it (if it's a simple phono jack), or put another in it's place on the dash. The aux in on the new unit will likely use rca connections, but you can run an rca cable, with an adapter to go on the end of it to whereever you need it.
