2005 kia sedona wiring
12volts71
Posted: January 05, 2007 at 2:06 AM / IP Logged
Looking for wiring for remote start wiring for 2005 kia sedona van.
Was wondering if anyone had it?
chris354
Silver - Posts: 253
Posted: January 05, 2007 at 2:09 AM / IP Logged
12volts red (30A), BLACK/ red (30A)  +  ignition harness
Starter BLACK / YELLOW to yellow  +  ignition harness
Second Starter N/A
Ignition WHITE/ blue to white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory green  +  ignition harness
Second Accessory white to blue  +  ignition harness
Keysense white  +  ignition harness
Power Lock WHITE/ black  -  plug left of steering column
Power Unlock RED / green  -  plug left of steering column
Lock Motor blue/red  5wi driver kick, door harness
Unlock Motor RED / yellow or BLACK / YELLOW  5wi driver kick, door harness
Parking Lights+ RED / black  +  driver kick, harness to rear
Parking Lights- WHITE/ red or white  -  headlight switch
Hazards WHITE/ green  -  hazard switch
Turn Signal(L) white  +  turn signal switch
Turn Signal(R) orange  +  turn signal switch
Reverse Light RED / green  +  kick panel, harness to rear
Door Trigger WHITE/ red  -  top of fuse box
Notes: Also found green (-) behind the instrument cluster, in the left plug.
Dome Supervision use door trigger wire
Trunk/Hatch Pin GREEN/ black  -  instrument cluster, left plug
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer yellow/red  ac  instrument cluster, left plug
Notes: Can also use green at ignition coil under engine cover.
Wait to start N/A
Brake Wire white  +  brake pedal switch
Parking Brake yellow/red  -  parking brake switch
Horn Trigger yellow/white  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2005 kia sedona wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: OM-Hyundai-1
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Only Canadian models have the immobilizer system. When using the 1100F or 1100X, a software change to 1100HKD is needed.
Friday, July 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
