2007 jaguar xk
frank_30
Member - Posts: 26
Posted: January 25, 2007 at 12:20 PM / IP Logged
any one with info on wiring on this car??? i know that its a negative pulse on most jags..any ideas!!!!
"throw it in the gutter and go buy another"
frank_30
Member - Posts: 26
Posted: January 25, 2007 at 8:38 PM / IP Logged
<> white wire green stripe:Ignition found at FL035   Solid Black:12v Constant found right in the middle of fuse panel. White wire red Stripe: Starter Inturupt found at FL037  now the only tricky part was that,because of the button start there was a pulse at ground to our unit.if corrected that by installing a relay to stop the pulse ground as follows: on boush relay 86 to Ign(WHITE/ green)  85 to ground,87 to our Ign wire and 30 to 12volt constant.  all this is under hood driverside removing  2 plastic covers and removing fuse 2 harness bolts and turning it over all wires are underside  pleanty of room..
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
