remote start wiring for 2007 sonata
rjlally
Posted: January 26, 2007 at 11:46 AM / IP Logged
I need a complete wiring diagram for a 2007 Hyundai Sonata for a remote start installation.
Also if anyone has any information on disabling or at least making quieter the seat belt alarm for this car I would appreciate it. It goes off every time you start the car and it's suprisingly loud. The dealer has told us that there is nothing he can do but he has gotten other complaints of the same thing. The 2006 model had the same feature but it was not as loud.
Installer_mss
Copper - Posts: 221
Posted: February 27, 2007 at 6:18 PM / IP Logged
i have for a 2006...is it the same as 07?  none-the-less here it is:
12volts pink (40A), red (30A)  +  ignition harness
Starter green  +  ignition harness
Second Starter N/A
Ignition blue  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory green  +  ignition harness
Keysense white  +  ign harn or BCM, wht 24P plug, pin 4
Notes: The BCM (Body Control Module) is under the center console, below the A/C controls.
Power Lock pink/black  -  DKP or BCM, wht 20 pin plug, pin 3
Power Unlock yellow/black  -  DKP or BCM, wht 20 pin plug, pin 11
Lock Motor gray  5wi driver kick, door harness
Unlock Motor red to white  5wi driver kick, door harness
Parking Lights+ BROWN / blk (L), GREEN/ blk (R)  +  driver kick, harness to rear
Parking Lights- pink  -  sw. or BCM, wht 20 pin plug, pin 4
Hazards brown  -  BCM, gray 24 pin plug, pin 9
Turn Signal(L) gray  +  turn signal switch
Turn Signal(R) green  +  turn signal switch
Reverse Light blue  +  driver kick, harness to rear
Door Trigger pink  -  BCM, wht 24 pin plug, pin 22
Dome Supervision yellow/black to yellow  -  BCM, gray 24 pin plug, pin 1
Trunk/Hatch Pin GREEN/ black  -  DKP or BCM, wht 24 pin plug, pin 23
Hood Pin green  -  pin sw. or BCM, wht 24P plug, pin 24
Trunk/Hatch Release white  -  DKP or BCM, wht 20 pin plug, pin 13
The trunk release motor wire is red (+) in the driver kick, harness to the rear.
The fuel lid release is GREEN/ black (+) in the driver kick, harness to the rear.
Power Sliding Door N/A
Factory Alarm Arm yellow  -  DKP or BCM, wht 20 pin plug, pin 1
Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm orange  -  DKP or BCM, wht 20 pin plug, pin 2
Disarm No Unlock see factory alarm disarm
Tachometer white or WHITE/ black  ac  instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is near the driver side shock tower under the hood. The tach wire is in pin 86 on the 2.4L, and in connector 1, pin 61 on the 3.3L.
For tach, can also go to any fuel injector and use the wire that is not black or orange.
Wait to start N/A
Brake Wire green  +  brake pedal switch
Parking Brake orange  -  parking brake switch
Horn Trigger white or yellow/orange  -  sw. or BCM, gray 24 pin plug, pin 8
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
remote start wiring for 2007 sonata - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
Installer_mss
Copper - Posts: 221
Posted: February 27, 2007 at 6:21 PM / IP Logged
if the seatbelt alarm stops as soon as you clip the seatbelt in, then just take the two wires from under the seat and to the seatbelt base and connect them together and the car will think the seatbelt in clicked in place all the time
