07 Chevrolet Malibu Alarm/Remote Start Wiring
mikvot
Gold - Posts: 1,043
Posted: February 05, 2007 at 6:56 PM / IP Logged
Has anyone done or have wiring info on an 07 Malibu?
Twelvoltz
Platinum - Posts: 2,384
Posted: February 05, 2007 at 9:44 PM / IP Logged
Audiovox lists:
          #510380: 2007 CHEVROLET MALIBU 4DR SEDAN SS WITH 3.9L ENGINE AND 6-SPEAKER AUDIO SYSTEM
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Starter 1          NO STARTER WIRE
               SEE OUR GM INTELLIGENT START INTERFACE TECHTIP FOR DETAILS
     All Door Trigger          USE LATCH WIRES
               YOU MUST DIODE ISOLATE ALL TRIGGERS TO MONITOR ALL DOORS.
     Domelight Super          USE DRIVERS LATCH WIRE
     LF Latch          GRAY/BLACK          (-)          AT BCM MODULE BEHIND TRIM AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
               PIN #51 - BLUE PLUG
     RF Latch          TAN/WHITE          (-)          AT BCM MODULE BEHIND TRIM AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
               PIN #72 - BLUE PLUG
     LR Latch          LIGHT BLUE/BLACK          (-)          AT BCM MODULE BEHIND TRIM AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
               PIN #54 - BLUE PLUG
     RR Latch          LIGHT GREEN/ BLACK          (-)          AT BCM MODULE BEHIND TRIM AT FRONT OF CENTER CONSOLE ON PASSENGER SIDE
               PIN #53 - BLUE PLUG
     Trunk Trigger          ORANGE / BLACK          (-)          AT BCM C1 GRAY 72 PIN CONNECTOR PIN 18
               ALSO AT BCM C3 41 PIN RED CONNECTOR PIN A3 (-), THIS WIRE MAY DIM CAUSING A FALSE TRIGGER. TEST ACCORDINGLY
     Alarm Disarm          LIGHT GREEN          (-)          AT BCM C1 GRAY 72 PIN CONNECTOR PIN 35
               GROUND THROUGH A 500OHM RESISTOR
     Alarm Arm          LIGHT GREEN          (-)          AT BCM C1 GRAY 72 PIN CONNECTOR PIN 35
               STRAIGHT GROUND
     Low Crr Pk Lights          BROWN / WHITE          (-)          AT BCM C2 GRAY 72 PIN CONNECTOR PIN 5
     Convenience
     Headlights-Lo          PINK/WHITE          (-)          AT BCM C2 GRAY 72 PIN CONNECTOR PIN 3
     Headlights-Hi          TAN/WHITE          (-)          AT BCM C1 GRAY 72 PIN CONNECTOR PIN 29
     Remote Start
     Accessory 1          BROWN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSKEY IIIŪ VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Tachometer          ANY FUEL INJECTOR          (AC)          ANY UNCOMMON WIRE
     Speed Sense          BROWN          (AC)          AT ECM C1 BLUE 56 PIN CONNECTOR PIN 22
     Low Crr. Pk Lights          BROWN / WHITE          (-)          AT BCM C2 GRAY 72 PIN CONNECTOR PIN 5
     Brake Lights          WHITE          (+)          AT BCM C1 GRAY 72 PIN CONNECTOR PIN 42
     Horn          TAN          (-)          AT BCM C2 LT. GRAY 68 PIN CONNECTOR PIN 9
               ALSO AT THE STEERING COLUMN HARNESS
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
mikvot
Gold - Posts: 1,043
Posted: February 07, 2007 at 12:04 PM / IP Logged
Thanks Twelvoltz!
