little black box
Patel
Copper - Posts: 86
Posted: February 03, 2003 at 9:02 PM / IP Logged
Was cleaning up the other day and found a "little black box".  I think Iknow what it is, but need you experts out there to verify.  Only sticker on it says AU-REC.  I believe its a channel expander.  It has a 5 wire harness (red, blk, blu, grn, vio).  Also a  1-10 on-off type siwtches, a dial for duration. and a little pull out pin thingy (like the ones found on some RS for 2nd IGN/ACC/STR).  Can someone tell me what this is and what usefull features i can use it for. I know i need an output from an alarm. but how does it know what channel is being activated.  can it be set for pulse/constant/lacthing/timed)  Thks in advance for any info.
securinu
Silver - Posts: 772
Posted: February 03, 2003 at 9:22 PM / IP Logged
with "au" it sounds like it is an omega unit of some sort.
Patel
Copper - Posts: 86
Posted: February 03, 2003 at 9:36 PM / IP Logged
yep it is an omega product, bought it to go w/ my excailber alarm, but never used it.  i guess i lost the wiring diagram.  can't find anything on the net about it.  just thought someone out there could help me out.
securinu
Silver - Posts: 772
Posted: February 03, 2003 at 9:46 PM / IP Logged
call 800-554-4053 tommorow and see if they can help it is their cust support #
Patel
Copper - Posts: 86
Posted: February 03, 2003 at 10:00 PM / IP Logged
Called Omega tech support.  They had no info on this unit.  They said it was too old a unit. Any info from anyone else?
thanks!!!
