Alarm wiring color/locations
sampoarE34
Member - Posts: 15
Posted: February 04, 2003 at 2:39 AM / IP Logged
Hello,
I am the proud owner of a BMW E34 520i from 1992,
But it's hard to find the right wires like tacho-signal (For remote start)
engine start,ign.#1,ign#2,doorlock,unlock wires.
Does anyone know the wire color&locations ? I have tried a online wiring-plan but thats only for newer models.
Any experience ?
Thanks in advance,
Sampoar E34
jayts95
Copper - Posts: 150
Posted: February 04, 2003 at 6:54 PM / IP Logged
|              12V|red                 |+  |steering column             |
|          STARTER|BLACK / YELLOW        |+  |steering column             |
|         IGNITION|green               |+  |steering column             |
|        ACCESSORY|purple              |+  |steering column             |
|       POWER LOCK|WHITE/ RED / yel *1    |+  |anti-theft plug *3          |
|     POWER UNLOCK|blue/RED / yel *1     |+  |anti-theft plug *3          |
| PARKING LIGHTS +|gry/purple,gry/yel  |   |at light switch             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|yellow              |+  |at light switch             |
|     DOOR TRIGGER|br/gry,br/blu,br/ppl|-  |anti-theft plug *3          |
|  TRUNK/HATCH PIN|RED / white           |+  |anti-theft plug *3          |
|         HOOD PIN|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|black               |   |at diagnostic conn. *2      |
|       BRAKE WIRE|blue/red            |+  |brake pedal switch          |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|                    |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 Do not operate locks by remote with door open or deadbolted to prevent possible damage to servos.  *2 Round plug with screw-on cover at pass. shock tower or by fusebox on driver's side.  *3 Anti-theft plug or module located under rear seat on passenger side. Door wires also found at general module under rear seat on driver's side. Be careful handling this module, as rotating it can cause underseat grommets to suck out, allowing eventual water damage to the electrical system. Domelight supervision wire BROWN / red at anti-theft plug.
sampoarE34
Member - Posts: 15
Posted: February 05, 2003 at 2:56 AM / IP Logged
Hi Jayts95.
Thanks for your reaction,
Where did you get this colors ? On the12volt.com i only find 525,535i and so on...
You sure its for a 520i ?
Where can i find the alarm-box connector because under rear-eat i see a blakc-box with a red eld but only with 3 tiny wires and a orange relay.
How can i activate "double-lock/arm factory alarm" which wire ? or both wires at same time ?
Regards,
Niels
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
