series parallel switching with relay
aznboi3644
Gold - Posts: 2,600
Posted: February 16, 2007 at 7:52 PM / IP Logged
I am going to be using a couple relays for switching my dual 2 ohm sub from 4 ohms for daily chilling to 1 ohm for when I compete or show off to my friends.
How big of relays will I need to handle 1200 watts safely.
Haem...I'm pretty sure you have this neat setup in your ride...what would you suggest
stevdart
Platinum - Posts: 5,816
Posted: February 16, 2007 at 10:26 PM / IP Logged
https://www.the12volt.com/relays/page5.asp#spvr
series parallel switching with relay - Last Post -- posted image.
See the above for switching from series to parallel on the special applications relays page.  Compliments of the12volt.
While you know that the amperage draw from the 12 volt battery / alternator source is high, you also know that the amperage is reduced dramatically to the speaker because of the high voltage amplifier source.  40 amp relays will do the trick with room to spare.  Standard 30 amp relays would do the job, too, I'm sure.
aznboi3644
Gold - Posts: 2,600
Posted: February 17, 2007 at 10:55 AM / IP Logged
Thanks Steve...I was thinking about 30 amp relays but I'll go with the 40 amp ones for some extra safety
Opinions on relays.
Which one of these is better
this or this
haemphyst
Platinum - Posts: 5,059
Posted: February 17, 2007 at 10:56 AM / IP Logged
The Bosch 30A relays will do just fine...
haemphyst
Posted: February 17, 2007 at 11:53 AM / IP Logged
Opinions on relays.
this or this
For the extra 4 dollars it'll cost overall, get the Bosch relays. The reliability is worth it to me...
aznboi3644
Gold - Posts: 2,600
Posted: February 17, 2007 at 8:47 PM / IP Logged
Alright cool...thanks haem
splaudio
Copper - Posts: 237
Posted: February 18, 2007 at 4:48 PM / IP Logged
i really would not recomending doing this because it will affect ur impedence.  if this is for a daily then spl set up dont do it...
haemphyst
Posted: February 18, 2007 at 8:31 PM / IP Logged
ummm... I think he wants to do this BECAUSE it will affect the total impedance. If you read the opening post, he WANTS to have a higher impedance for everyday use, and a lower impedance (and therefore, more power, thus, more SPL) for showing off...
Why is it your recommendation he NOT do this?
aznboi3644
Gold - Posts: 2,600
Posted: February 19, 2007 at 2:01 AM / IP Logged
I also wanna know why you don't recommend this??
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
