2007 chevy impala stock radio wiring
mikegzup
Posted: February 18, 2007 at 5:12 AM / IP Logged
I need a wire diagram for a 2007 chevy impala stock radio. Im trying to hook up three power acoustic subs in a box and a thousand watt amp to my stock radio. I prefer to keep the regular look of the dashboard for the moment. I also was wondering if the radio comes stock with rca plug ins. Im going to install the speakers my self with my brother and I bought  a 4ga. amp installation kit. I think I need a piece to hook the amp and speakers to the radio but Im not sure what the piece is called and the best way to install. Not trying to do much I just want a little vibration in my whip when I ride. If someone knows exactly what the pieces are I need to connect my sounds to the stock please let me know along with where I can find a diagram of the wires. If possible also an easy step by step on how to install them also. Thanks
errrryday im hustlin'
cutter1122
Copper - Posts: 103
Posted: February 18, 2007 at 8:37 AM / IP Logged
2007 chevy impala stock radio wiring - Last Post -- posted image.
mikegzup
Posted: February 18, 2007 at 12:53 PM / IP Logged
When I took the stock radio out of my dashboard There were two plug-ins. One was what looked like a harness. (It had a number of multi color wires connected to one peice whhich was connected to the radio.) The other was just one single cord (which lookd like a microphone plug-in). I was told I need to hook my rca and  the remote wire to the back of the stock radio. Which is the best way to do that, and what guage wire is reccomended for a 1000 watt amp with 3 10' subs.
Installer_mss
Copper - Posts: 221
Posted: February 27, 2007 at 12:34 AM / IP Logged
just hook the remote wire up to accessory at the fuse panel (the ignition harness is best but hard to get to in that car) or if it has a factory amp use the pink wire behind the radio
use a line output converter, AKA - line level adapter, AKA - LOC, AKA - LOC80 for the RCA cables
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
