static from brand new tweeters
milanocivic97
Member - Posts: 9
Posted: March 18, 2007 at 8:59 PM / IP Logged
i just installed a new pair of components and there is a slight static coming from the tweeters...it's very annoying
my setup is:
CDT Audio EF-61FG with TW-25 Tweeters.
Alpine CDA-7892 HU with Media Exander set to "Mp3 Mode" (seems to have the least static.) the internal amp is bypassed and the high pass filter is set at 80hz.
Alpine MRP-F250 Amp bridged to 2ch with gain at 0 running the components.
8g stinger power wire routed away from stinger interconnect going to the amp.
big 3 upgrade with 0/1g power wire.
peripheral electronics ipod cord.
i tried various cd's and the static shows its ass worse. at least the problem is fixable whether it be new tweeters (hope not, mine are BRAND NEW), my wiring, or something else.
to be more specific on my current setup the 6.5's are mounted in a 3/4" mdf ring that is mounted to a sound deadened door with an airtight seal around it and the big holes covered with sound deadening. my headunit is an alpine cda-7892 with the internal amp bypassed. the gain on my bridged mrp-f250 amp is currently at zero but it gets plenty loud. with this setup i highly doubt im overdriving anything at all.16g monster standard wire goes from the amp to the crossovers to the speakers. the tweeter wire had to be extended to be mounted in the factory locarion behind the sideview mirror, this is where my problem might be. the connection is somewhat ghetto because i lost my soldering iron and had no more crimp connectors. they are twisted and electrical taped...
any help would be great.
stevdart
Platinum - Posts: 5,816
Posted: March 18, 2007 at 9:57 PM / IP Logged
Solder your connections, or at the very least properly crimp them.  You should have eliminated that possiblilty right from the start.  Second thing that strikes me...your gain setting.  How did you arrive at "0" setting?  Is it because the amp is labelled as "NOM" in that general area of the gain travel?
DYohn
Platinum - Posts: 10,741
Posted: March 18, 2007 at 10:06 PM / IP Logged
Also you may want to improve the ground on your amp and on your HU.
milanocivic97
Member - Posts: 9
Posted: March 18, 2007 at 11:20 PM / IP Logged
i believe the grounds on both the amp and hu are fine. i will solder the connections in the morning. when i said the gain was at 0 i meant it is turned all the way down...sorry about that.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
