2006 Nissan Pathfinder Radio Wiring
jccb
Posted: April 18, 2007 at 12:30 PM / IP Logged
     Need the wiring to install audio for a nissan pathfinder 2006 please.  thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: April 21, 2007 at 10:22 AM / IP Logged
Get your self a harness adapter...... make it easy!  If you need to cut the harness.....
+12V DC Battery(Constant)Yellow See notes for the satellite radio. 29 20 amp Fuse block in right rear of engine compartment
Switched AccessoryGREEN/ black Radio pin 10; satellite radio pin 26. 10 amp Fuse block behind right side of dash
Ground Chassis
Power Antenna NCA Antenna signal wire (green) connects radio pin 5 to antenna amplifier pin 1.
Illumination Red & gray
Steering Wheel Control Wire Red & gray Blue is a ground wire. These connect to radio pins 74 to 76.
Left Front + Brown
Left Front - Blue
Right Front + Light green
Right Front - Red
Left Rear + Green
Left Rear - Black
Right Rear + Gray
Right Rear - Orange
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
