dome light relay
rustie.crust
Posted: May 08, 2007 at 5:38 PM / IP Logged
hi guys could someone please tell me is it possible to modify the relay diagram below to bypass the dome light delay on a 51 plate fiat punto as it keep triggering my alarm   thanks in advance     rich
Here is the same drawing modified with the Relay contacts drawn in so you can see what is going on.
dome light relay - Last Post -- posted image.
hotwaterwizard
Silver - Posts: 1,350
Posted: May 18, 2007 at 8:38 AM / IP Logged
More explaining is needed I don't understand what you are trying to do.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: May 18, 2007 at 8:52 AM / IP Logged
Stockton California
rustie.crust
Posted: May 18, 2007 at 11:24 AM / IP Logged
my dome light stays on for about 15 seconds when i lock the doors so the alarm thinks the doors are open and triggers the alarm
hotwaterwizard
Posted: May 18, 2007 at 2:54 PM / IP Logged
I would Just add another pin swith for the alarm instead of using the one for the dome light.
Stockton California
rustie.crust
Posted: May 18, 2007 at 4:37 PM / IP Logged
thanks do you mean add a pin switch to every door to trigger the alarm                    thanks for advice rich
hotwaterwizard
Posted: May 18, 2007 at 8:38 PM / IP Logged
Yes, Then you don't have to mess with that stupid Light Supervision Circuit board.
Stockton California
nizmotec
Posted: May 22, 2007 at 10:25 AM / IP Logged
what kind of alarm is it?
if it has dome light delay feature,enable it,this will cause it to ignore the dome light being on while arming.
the Real Xtreme,accept no Fakes!
