2007 Chevrolet Cobalt Alarm/Remote Start Wiring
rmk2252004
Posted: May 11, 2007 at 10:37 PM / IP Logged
Anyone have the wiring diagram info on a 2007 chevrolet cobalt greatly appreciated!!!
KarTuneMan
Platinum - Posts: 7,056
Posted: May 12, 2007 at 11:09 AM / IP Logged
12 VOLTS RED / black C3 plug on BCM in center console   +
 The BCM is located in the passenger side of the center console. See the provided image for more information.
 IGNITION Yellow Ignition switch harness or C4 plug on BCM   +
 ACCESSORY Brown Ignition switch harness or C4 plug on BCM   +
 STARTER SEE NOTES
 No connection is required for remote start. When accessory shuts down during the start cycle the vehicle will crank automatically.
 TACH SIGNAL Use an injector wire
 FUEL INJECTOR Opposite from Pink At any injector on engine   AC
 LOCK White C1 plug on BCM in center console   -
 1-wire system. Ground (-) to lock and ground through 1.5K resistor to unlock. The BCM is located in the passenger side of the center console. See the provided image for more information.
 UNLOCK White C1 plug on BCM in center console   -
 DOORPIN SEE NOTES
 Driver's door (Gray/black) and Passenger door (Tan/white) are both found on the C1 plug at the BCM in the passenger side of the center console.
 TRUNK PIN ORANGE / black C1 plug on BCM in center console   -
 TRUNK RELEASE Tan C2 plug on BCM in center console   -
 SUN ROOF OPEN Dk.green At switch in overhead console   Rev Pol
 SUN ROOF CLOSE Lt.green At switch in overhead console   Rev Pol
 FACTORY ARM With OEM remote only
 FACTORY DISARM With OEM remote only
 BRAKESWITCH Lt.blue C2 plug on BCM in center console   +
 PARKLIGHTS Brown C3 plug on BCM in center console   +
 HAND BRAKE Lt.blue C1 plug on BCM in center console   -
 HORN Tan C2 plug on BCM in center console   -
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
