93 s-10 start problems
Silvrefox
Copper - Posts: 126
Posted: May 14, 2007 at 8:48 PM / IP Logged
Just got my first S-10 project, 93 w/188k on it. Runs fine, but only problem is if I drive it for bout an hour, go inside for a bit come back out to start it and it won't start. It cranks and cranks, but no start. 93's don't show to have passlock, so what gives? Any you fellas know where to start?
jmelton86
Gold - Posts: 1,228
Posted: May 14, 2007 at 9:07 PM / IP Logged
2.2L?
I sometimes have the same problem with my '95 Cavalier (Same motor, except motor mounts. They changed to diff. 2.2L in '96). It helps to turn the key all the way off before trying again.
I don't know what the prob. is, maybe you should let the fuel pump run for 2 secs. (like it's supposed to, in any FI vehicle) so the injectors can prime...
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Silvrefox
Copper - Posts: 126
Posted: May 14, 2007 at 9:37 PM / IP Logged
Funny thing is, wait 30-45 mins and voila!!
Hymer
Silver - Posts: 695
Posted: May 15, 2007 at 11:27 AM / IP Logged
probaly a bad spider injector thing under the intake... or poor fuel pressure... Its either fire or fuel, to much or not enuf...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
jmelton86
Gold - Posts: 1,228
Posted: May 15, 2007 at 6:58 PM / IP Logged
With my Cavalier, same motor, it still does it every week or so. Mostly when cold. I've done the wires/plugs/air-fuel filter/oxy-sensor/Seafoam (one of the best fuel system cleaners) thing so I don't know...
Big3 in 1/0G
1/0G to GTO14001
subconceptz
Member - Posts: 31
Posted: June 03, 2007 at 11:42 PM / IP Logged
Check to see if you have spark on all cylinders with a spark tester or a screw driver in the end of the spark plug boot and let it touch ground. It sounds like you have something getting "HotSoaked". It is a condition where an electrical device will become too hot internally and break down after it sits for awhile while it is soaking up heat. I would recommend checking that and if you have no spark then you need to check the ignition module or coil pack depending on which motor you have. It will either be a 2.2l 4 cylinder, 4.3l throttle body injected, or a 4.3l Vortec port type injected. It sounds like an ignition problem to me. Hope this helps out.
