starsound
deemo
Member - Posts: 11
Posted: May 20, 2007 at 3:35 AM / IP Logged
i've replace 2 transistors on 1000w starsound amp,but when i do a test run it's automatically
cuts out on that same transistors....must i get stronger transistors?
thanx
deemo
deemo
DYohn
Platinum - Posts: 10,741
Posted: May 20, 2007 at 11:37 AM / IP Logged
Most likely the reason the transistor blew in the first place has not been fixed.  It is not enough to simply replace a bad component unless you know why it went bad.
deemo
Member - Posts: 11
Posted: May 21, 2007 at 2:53 AM / IP Logged
i'm gonna replace the transistors and the caps that works around that transistors i'll get back to u if it works or not........
deemo
DYohn
Posted: May 21, 2007 at 8:22 AM / IP Logged
Well, maybe you missed my point.  WHY are the ICs blowing?  Have you completely tested out the REST of the amp to make sure there is noting wrong in the power supply, in the input side or the feedback circuit, or elsewhere?  Just replacing what's blown only works sometimes.
wotugot4me
Copper - Posts: 64
Posted: May 21, 2007 at 10:54 AM / IP Logged
Is it worth repairing?  Starsound amps are not usually that expensive anyways.  Just wondering if all the spare parts and time is worth it.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
