1995 Nissan 240s
sclinton
Posted: May 25, 2002 at 12:55 PM / IP Logged
I am going to install an alarm on a 240sx and requesting the diagram
Steven C.
Platinum - Posts: 12,488
Posted: May 26, 2002 at 1:44 AM / IP Logged
Nissan
240SX
1995
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK / YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ RED
Ignition #2:
WHITE
Ignition  #3:
N/A
Accessory:
WHITE/ BLUE
Brake  Light:
RED / GREEN (+)
SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
YELLOW/RED
PIN 3 AT ECCS *
Parking Lights:
RED / BLUE
(+) AT HEADLIGHT SWITCH
Headlights:
SEE NOTES BELOW
OEM Alarm  Disarm:
GREEN/ YELLOW (-)
SAME CONNECTOR AS DOORLOCKS
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Electronic Concentrated Control System (ECCS) Module Located In Pasenger Kick Panel. Pin #2 Is Also YELLOW/RED Tach Wire. These Wires Are On Short Side Of Connector Near Center Bolt. LT. GREEN/ BLUE At Distributor Is High Signal. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold;
Nissan
240SX
1995
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
IGNITION SWITCH HARN.(WHT/RED FOUND)
Starter  Kill:
BLACK / YELLOW
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
RED / WHITE
(-) DRIVER KICK PANEL ***
OEM Horn:
GREEN / WHITE (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
LIGHT GREEN / WHITE
@ WHITE 12 PIN CONN. IN DR. KICK ****
Power  Unlock:
BROWN / RED
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE
Notes:
*** SE Models Are Diode Isolated. Wire In Bottom Row Of Main Body Harness Conn. In Driver Kick Panel. Proper Wire On Base Model Is BLUE. ****  Negative Pulse Door Lock .
sclinton
Posted: May 28, 2002 at 8:15 AM / IP Logged
Thanks a Lot This is going to be my first install on a 240sx !!!!
Steven C.
Posted: May 28, 2002 at 9:51 AM / IP Logged
Good luck 1995 Nissan 240s - Last Post -- posted image. If you need any more help just post your requests.
