autopage rs 655 and door poppers
lmarinukjr
Posted: June 14, 2007 at 10:55 PM / IP Logged
ok i have shaved handles ok my 93 ranger. i have an autopage rs-655 alarm and i bought a popper kit with relays can someone help me with wiring the popper kit into the alarm.i have no power locks so i was kinda hopping to be able to pop the drivers side and passenger side with either the unlock button and aux button or i have heard that some alarms will pop he driversside with the unlock button then hold the same button for the passengers side.
thanks
larry
swerve
Copper - Posts: 149
Posted: June 18, 2007 at 11:24 AM / IP Logged
if your alarm has a second unlock wire you can use that to unlock the pass door. when you push unlock a second time it will send a pulse to that wire. connect that to the pass side and the driver side to the normal unlock wire. you might have to change the programming in the alarm to make it work.
git yer swerve on!
lanman31337
Copper - Posts: 83
Posted: June 19, 2007 at 12:42 PM / IP Logged
I have shaved handles and locks, and on my alarm i have a 2nd channel.  I put the passenger door on the unlock, and the driver's side on the secondary channel.  If you wire it up like swerve mentioned, when you hit the unlock the 2nd time, both doors pop open.
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
