relays electric after run water pump
mboniface
Posted: June 17, 2007 at 11:38 AM / IP Logged
Desperately need help !!
I have a 1986  Audi coupe with a turbo engine.
I want to add an electric water pump, which turns on (during ? ) and after the engine is turned off. It will be activated when the engine is hot and turn off after it has cooled down.  Why ? to help coolt he turbo down after engine is shut down.
I have been told to use two relays one (87,86, 85, 30) the other(87, 87A, 86, 85, 30). This works in part, however the (87,86, 85, 30) relay gets very hot and practically drains my battery overnight. Maybe I'm using the wrong type of relays ? Maybe a relay that remains on for 8-10min. and turns off ?
This is what I have:  12v. electric water pum and a Thermo switch.
What I want to know is how should I wire it uP. What relays other than those below could I use ?
All considerations would be most appreciated.
Miguel Boniface
KPierson
Platinum - Posts: 3,527
Posted: June 17, 2007 at 12:56 PM / IP Logged
With the limited information you gave, I would assume you can do this with one relay:
30: 12vdc battery (fused for whatever the water pump recomends)
87: Output to water pump
85: +12vdc output from thermo switch
86: Ground
Wire the other side of the thermo switch to the battery (constant 12vdc)
How much current does the water pump require?  You need to make sure your relay is capable of driving the load.
Kevin Pierson
mboniface
Posted: June 17, 2007 at 5:17 PM / IP Logged
Kevin,
Thank you for the reply. You're right ... At the risk of not wanting to be complicated, I guess I wasn't very clear. Maybe it would be simpler to put my problem as a question.I f you wanted to wire up an electric water pump so that it came "on" after you removed the engine from the ignition, what would you do ?
You have two items: a 12volt pump with two pins (+ and -).  Your thermoswitch has two pins as well (+ and - ) The thermoswitch will activate the pump when the engine has  been turned "off" and is above a certain temp. (not important for this exercise) and open it as sson as the engine temp. has dropped down again.
I think a 30amp relay will do the job.
Regards,
Miguel
KPierson
Posted: June 17, 2007 at 7:22 PM / IP Logged
I would still wire like I said in my first post.
Wiring it that way will allow it to come on after the ignition is shut off and the temp is above the thermo switch setpoint.  The way I described would be completely independent of the ignition status.  You 'may' want to put some sort of time dely off on the circuit just to protect the battery incase the switch sticks.
Kevin Pierson
hotwaterwizard
Silver - Posts: 1,350
Posted: June 19, 2007 at 12:52 AM / IP Logged
relays electric after run water pump - Last Post -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
dualsport
Silver - Posts: 983
Posted: June 19, 2007 at 8:23 AM / IP Logged
Just as a general suggestion for wiring relay controls- if possible, use a ground switching setup for the relay so that if the control wire gets inadvertently shorted to ground, it will only turn on the relay rather than shorting 12V to ground.
Some thermoswitches shunt to ground when active, so it may be necessary to do this anyway.
Just have to connect one side of the coil to the +12V power at terminal 30, and then the other side is wired to the thermoswitch, which should be set up for ground when active.
hotwaterwizard
Posted: June 22, 2007 at 8:42 AM / IP Logged
I like switching the Hot. A short is a short and I see no difference in performance.
You see I work on Hot Water Pressure Washers and they always switch the Hot.
Stockton California
KPierson
Posted: June 22, 2007 at 10:50 AM / IP Logged
As long as the line is properly fused it really doesn't matter.  In a car, it is typically more convenient to switch the (-) because you don't have to run two wires (you can ground the switch at the switch).  However, if you are already working under the hood it really isn't going to save much.
Kevin Pierson
dualsport
Silver - Posts: 983
Posted: June 23, 2007 at 7:59 AM / IP Logged
By all means switch the hot side if there's a reason for it. It's done with light fixtures for safety reasons because you don't want 115V sitting on the base of the bulb socket when the light fixture is off.
For relays, there's an advantage to ground switching because it's easier to find a local ground source for the switch than a 12V source, allowing the use of a single control wire. Most electronic controls such as alarm modules use ground switching for the relays.
If it's not possible to use ground switching if your specific situation, then go the other way- either way works; just consider the options.
