relay for water injection
graemesimpson
Member - Posts: 24
Posted: June 27, 2007 at 9:58 AM / IP Logged
Hi People,
I am about to embark in installing Water Injection system to my car, part of this system is using a "Surflo Water Pump", this required a 12volt ignition feed.
Obviously I will be putting a fuse on this line, but was wondering if it would be better to put a relay in the system or just wire direct to a switched ignition feed ??
If using a relay, how would I wire it into the circuit.
Many thanks
KPierson
Platinum - Posts: 3,527
Posted: June 27, 2007 at 11:17 AM / IP Logged
How much current does the water pump pull?  Where will it be mounted?
If it pulls under ~10A and is mounted in the engine compartment I would probably hardwire it.
If it pulls more current, and is mounted in the trunk, I would run a dedicated wire directly to the battery and use a relay.
The relay would be wired like:
Pin 85 - Ignition
Pin 86 - Ground
Pin 30 - Fused battery power
Pin 87 - Water pump output
Kevin Pierson
hotwaterwizard
Silver - Posts: 1,350
Posted: June 29, 2007 at 11:35 PM / IP Logged
Which Pump?
http://www.shurflo.com/pages/Food_Service/water/categories/deliverypumps/main.html
8005-243-250
12 VDC Delivery Pump w/Bypass
12 VDC, 1.0 GPM open flow, 60 PSI Demand Switch, w/45 PSI Internal Bypass,
3/8" NPT-Female ports, NSF Listed, UL/CSA recognized.
2088-554-144 Delivery Pump
12 VDC, 3.5 GPM open flow, Santoprene® valves, Santoprene® diaphragm,
45 PSI Shut-off, 1/2" MPT Ports, NSF listed
100-000-20 Single Fixture Delivery Pump 12 VDC
without motor enclosure, 3/8" hose barb ports, 1.0 GPM open flow
Here is a Diagram You can ommit the resistor and Led if you don't want a light to let you know when it is on.
relay for water injection - Last Post -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
