1995 toyota tercel, brake switch
soundman07
Posted: June 29, 2007 at 10:30 PM / IP Logged
I have a problem with the brake switch, either a short or possible bad switch. I hope to get a color code wiring diagram, to allow for a jump wire test to determine if it might be a bad brake switch or a dead short.
At this time the brake lights are staying lit all the time. and pulling the fuse is the only way to turn them off.
If anyone can help it would be appreciated...
Thank you in advance
Soundman07
KarTuneMan
Platinum - Posts: 7,056
Posted: June 30, 2007 at 12:33 PM / IP Logged
Sounds to me like a bad switch @ the brake pedal. Can you pull the brake pedal UP and shut the brake lights off?
I say get down under the dash and see if you can pull the switch. The wire color @ the switch is GREEN / WHITE.
soundman07
Posted: July 01, 2007 at 7:35 AM / IP Logged
Thanks for the info, it was a switch connection. replaced it and it is working 100% just want to add that this site is superb and will remain on my favorite list for future reference, and will be sure to advise anyone else to help them through any problems they may encounter.
Thanks very much!
soundman07
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
