anyone make sense of this diagram
jjl12
Posted: July 02, 2007 at 12:21 AM / IP Logged
Can anyone decipher the wiring for this DPDT relay used in the kill switch. I am not that conversant with relay wiring (std relays Ok, but the DPDT has me baffled in this diagram)
The link for the complete setup is
http://autospeed.drive.com.au/A_107975/cms/article.html
anyone make sense of this diagram - Last Post -- posted image.
KPierson
Platinum - Posts: 3,527
Posted: July 02, 2007 at 8:21 AM / IP Logged
Wire 12vdc to one side of the coil
Wire the other side of the coil to ground, through a magnetic switch
Now you have two sets of contacts:
Contact A:
C - (-) side of coil
NO - to ground through a NC pushbutton switch
NC - No connection
Contact B:
C - 12VDC
NO - (+) output to drive 'Heavy duty automotive relay'
NC - flashing LED (not actually necesarry)
Kevin Pierson
meh66
Copper - Posts: 266
Posted: July 02, 2007 at 2:23 PM / IP Logged
The LED is used as a visual  indicator to let you know if the immobiliser is activiated or not.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
KPierson
Posted: July 02, 2007 at 3:41 PM / IP Logged
And thus not actually needed to make the system function as designed.
Kevin Pierson
jjl12
Posted: July 03, 2007 at 2:51 AM / IP Logged
Thank you for your replies. I will put the system together tomorrow to see if it works as described.
Jeremy
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
