breaking in speaker connectors, myth?
frans-c
Copper - Posts: 77
Posted: July 03, 2007 at 5:46 PM / IP Logged
Today I completely re-did my amps' power, ground and speaker connections, seeing that my original installation was - in my mind - a bit dodgy... I recently purchased a new, proper ratchet crimping tool, which I used today.
Well, I've heard on a South African forum that you need to allow for a certain breaking-in period for the wires and connectors. I always thought that this was bull, until today.
My sound is way different after I finished, unfortunately not for the better, the sound being a lot brighter and harsher than before. Previously, when I changed something on a single driver, I thought that it sounded a bit different afterwards, but with time it got "better", which I hope will happen again this time.
I tried a search for "myth", but couldn't find anything relevant. What's your experience on this?
F R A N S
1985 Mercedes-Benz 230E
320 000 km / 199 000 miles
Full MB Service History
haemphyst
Platinum - Posts: 5,059
Posted: July 03, 2007 at 6:08 PM / IP Logged
Poor connections could be a point of oxidation, which CAN have an audible effect on the overall response. Tight connections will be a much lower impedance connection, and can change the tonal quality of a system.
I always try to make certain my connections are oxide-free, AND tight... TIGHT is important, especially in a car!
DYohn
Platinum - Posts: 10,741
Posted: July 03, 2007 at 8:19 PM / IP Logged
Wires do not "break in."  They might get warm with usage, but that's it.
kassdog
Copper - Posts: 257
Posted: July 04, 2007 at 1:39 AM / IP Logged
You sure it wasn't mistaken for speaker break in. There is a really good sticky on that subject.
frans-c
Copper - Posts: 77
Posted: July 06, 2007 at 11:04 AM / IP Logged
Well, I decided to find the reason behind my front stage sounding like Rice Crispies (I assume you know what that is, compliments of Kellogg's breaking in speaker connectors, myth? - Last Post -- posted image. ). It simply didn't make sense to me that after I improved my setup's connections, that the sound could be worse than before.
Well, here's the deal. It seems as though my front components are receiving a little more power all of a sudden, resulting in my dash grilles vibrating horribly. So I took some acoustic carpet I had left from my sub-box, and lined the speakers with it, in the hope that it would cure the problem; or at least eliminate any direct plastic to rubber contact. It worked, thank goodness! It's now back the way it was - perhaps even better than before!
One final question: is it possible that my amps are delivering a little more power after I changed the connections? My previous connections weren't terrible, but now they're absolutely 100%.
F R A N S
sarcomax
Copper - Posts: 276
Posted: July 06, 2007 at 12:12 PM / IP Logged
As haemphyst pointed out, if there was oxidation at the connections the resistance may have been higher, and there may have been enough to cause a decrease in performance.
You are only as strong as your weakest crimp.
buyadonkey, or however you spell it...
frans-c
Copper - Posts: 77
Posted: July 06, 2007 at 12:22 PM / IP Logged
You mean "baie dankie" breaking in speaker connectors, myth? - Last Post -- posted image. ?
F R A N S
sarcomax
Copper - Posts: 276
Posted: July 07, 2007 at 11:06 AM / IP Logged
Yup that's it! I have a friend from south africa that taught me that. He just never spelled it.
Now I know!
