toyota echo 2005 power doors
johnbelzile
Posted: July 06, 2007 at 10:52 PM / IP Logged
Power Lock BLACK/ red to BROWN / yellow  -  driver kick, 14 pin plug   toyota echo 2005 power doors - Last Post -- posted image.
Power Unlock blue / YELLOW to yellow/black
I don't understand the system on the power doors Toyota Echo 2005.
My remote starter have negative output for lock and unlocking..
black red to brown yellow... toyota echo 2005 power doors - Last Post -- posted image. Etc
Can you explain me??
P.s Sorry for my english , i'm a french canadian
spookiestylez
Silver - Posts: 531
Posted: July 06, 2007 at 11:03 PM / IP Logged
Directechs is saying that the locks are in fact (-)trigger, but that the color of the wire changes from BLACK/ red into brown yellow, depending on where the wire is located.Always test your wires with a DMM (digital multimeter)
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock      blue / YELLOW to yellow/black       -       driver kick, 14 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder. Unlock requires a double pulse.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is GREEN/ black (-) in the passenger kick in a 14 pin plug.
rtfm
johnbelzile
Posted: July 07, 2007 at 7:30 AM / IP Logged
Thanks a lot!
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
