wiring for 2006 gmc sierra 3500hd
rudydapimp
Copper - Posts: 390
Posted: July 14, 2007 at 2:32 PM / IP Logged
looking to put an old Avic-N2 into this truck.  I can find speed sense, tach, but anyone know what the reverse wire is for this truck???
Thanks in advance!
KarTuneMan
Platinum - Posts: 7,056
Posted: July 15, 2007 at 5:07 PM / IP Logged
TACH SIGNAL SEE NOTES
 There is a coil for each cylinder, each with a 4-pin plug. Each plug contains a BLACK, BROWN & PINK, as well as a 4th wire which changes color on each coil. This 4th wire can be used as your tach reference, set your remote starter for a 1 cylinder signal.
VSS WIRE GREEN/ black At PCM left front of engine compt.   AC
The reverse should be in the drivers kick. Lt. Green, @ the junction box.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
