wiring for 12 volt plug 2004 f 150
garyjepp
Posted: July 18, 2007 at 9:23 AM / IP Logged
I was wondering if anyone knows what the three wires coming from the 12-volt plug are --
grey/white, grey/red and black
Specifically, I want to connect my Sirius satellite radio to the 12-volt line.
Thanks for any help that can be provided.
belfour
Member - Posts: 13
Posted: July 18, 2007 at 12:53 PM / IP Logged
Tap into the ign source on the back of the deck, that way it will only come on when the radio is on
garyjepp
Posted: July 20, 2007 at 8:42 AM / IP Logged
Yes, that is what I want to do -- any idea of which of the many colored wires I am supposed to tap into?
belfour
Member - Posts: 13
Posted: July 20, 2007 at 6:35 PM / IP Logged
Radio 12v lt. GREEN/ purple   +   radio harness
Radio Ground black and BLACK/ lt. green   -   radio harness
Radio Ignition pink/black or lt. GREEN/ YELLOW +   radio harness
Test them first, Which sat radio do you have? The new ones are 5 volts, so you cand cut the end off and put in an inline fuse, so I use a cig adapter and hardwire it, be sure to tape them together so they dont fall apart.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
