69 cadillac, video connections
bedfordproaudio
Posted: August 07, 2007 at 11:18 AM / IP Logged
Hi, everybody, first off, im new to the forum.  I have a 69 cadillac that im completly redoing.  I have a system that i want to install but im not quite sure about all the video stuff.  Here is what i have and i kinda need someone to point me in the right direction and possibly a basic diagram drawn up?
First off I have a Jensen VM 9020TS double din head unit.  I have two power acoustic 7 " monitors that im putting in the headrests and they have two sets of jacks.  I also have a farenheit 4 input audio & video controller, and i want to run an x-box and a power converter.  The audio i could peice together, but the video is in question.  If someone can kinda basically tell me how to connect all these together and with what kinda connectors i would greatly appreciate it.  Thanks, Jason
ceasar326
Copper - Posts: 239
Posted: August 07, 2007 at 4:38 PM / IP Logged
I have a jensen  vm9411 indash. I think my instructions would be the same for yours.
Now first of you would need a multi video amplifier to hook up both 7" acoustics and farenheit. The multi video amp is a 4 video outputs with video levels and 1 video input.
You would hook up the video input from the multi video amp to you jensen yellow jack "may say rear video out 1"
Your x box consel jacks red, blk, and yellow would go as follow. Red jack from the x-box to red jack from jensen  "aux in/r". blk jack from x-box to blk jack from jensen "aux in/l" yellow jack from x-box to yellow jack from jensen "aux in video"
The extras jacks from the 7" acoustic could be used for something alse like more consels playstation 2 or more
Hope this helps
bedfordproaudio
Posted: August 08, 2007 at 6:47 AM / IP Logged
Thanks, what about the jacks from the headrest tvs?  do i plug all red, yellow, and black into the video amp?  and which plugs?
ceasar326
Copper - Posts: 239
Posted: August 08, 2007 at 9:27 AM / IP Logged
The  yellow jack from the headrest gets connected to the video amp. The red and black are audio inputs. If your having sound coming out of your car speakers you wound need to plug in your red and black jacks of the headrest.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
