35w to 55w
blkb7
Posted: August 11, 2007 at 11:46 AM / IP Logged
i'm trying to kill the dead bulb light in my cluster from my hid fogs
i need to trick it by having the output to 55w instead of 35w, is there anyway to do this
thanks
Ween
Platinum - Posts: 1,368
Posted: August 12, 2007 at 9:49 PM / IP Logged
hi,
you'll need to read up a bit on Ohm's law..but here's the basics
20 w @ 14 v = 10 ohms (close enough),
so you need to add a 10 ohm resistor in parallel with the input side of your ballasts.
the power value of the resistor must be taken into consideration also.  a 20 w resistor may well work but for a safety factor, you'd increase the value to 50 w.
20 w is a significant amount of power / heat to dissipate (think about a small soldering iron), so you'll also need a heat sink to remove the heat into the air.  if you can mount the resistors/ heat sinks where air is flowing across them, it would definitely be desirable
hope this helps
mark
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
