2005 buick lacrosse vss
baovuong
Member - Posts: 21
Posted: August 27, 2007 at 10:57 AM / IP Logged
I am looking for the VSS wire for a 2005 Buick Lacrosse (Allure - canadian name).
ceasar326
Copper - Posts: 239
Posted: August 27, 2007 at 11:02 PM / IP Logged
BUICK / LACROSSE / 2005 / Accessory
12volts red  +  battery or fuse box
Ignition pink  +  ign harness or BCM, C1, pin 22
Notes: The BCM is to the left of the steering column. C1 is a 52 pin black plug. C2 is a 52 pin black plug. C3 is a 18 pin black plug.
Parking Lights+ brown  +  fuse box or pass kick, harn. to rear
Parking Lights- BROWN / white  -  switch or BCM, C3, pin 8
Headlight white  -  switch or BCM, C3, pin 7
Trunk/Hatch Release lt. blue  +  BCM, C2, pin 45
Power Sliding Door N/A
Speed Sense dk. green    ECM/PCM in air cleaner assembly
Notes: 3.6L vehicles, it is in the black plug, pin 22. 3.8L vehicles, it is in the blue plug, pin 22.
Wipers gray  +  BCM, C1, pin 12
LF Window up/dn dk. blue - brown  A  driver window switch in door
RF Window up/dn lt. blue - tan  A  driver kick, door harness
LR Window up/dn dk. green - purple  A  driver kick, door harness
RR Window up/dn lt. green - purple  A  driver kick, door harness
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2005 buick lacrosse vss - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface
Required:
No
Type:
Data Bus
Part #: 1900G
Alternate Part1 #: IM-GMSD-1
Notes:
Combo Interface
Required:
No
Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the PASS-Key III, but it will not control the door locks on this model year.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
