rockford fosgate t4004 or p450.4?
pistons23
Posted: October 29, 2007 at 6:08 PM / IP Logged
i have a regular cab 2000 ford ranger.  i recently installed a pioneer deh-3900mp reciever.  i have a set of infinity kappa 60.7cs(2ohms) components(2-90RMS/270Peak) waiting to be installed.  this is where i need help.  since those components run at 2ohms i need a amp to power them.  in the future i would like to run a shallow sub behind the seat, so it has to be a 4 channel amp.  ive come across 2 models that might work.
Rockford Fosgate Power T4004
25W x 4 @ 4-Ohms RMS
50W x 4 @ 2-Ohms RMS
100W x 4 @ 1-Ohm RMS
100W x 2 @ 4-Ohms bridged RMS
200W x 2 @ 2-Ohms bridged RMS
Rockford Fosgate Punch P450.4
60W x 4 @ 4-Ohms RMS
110W x 4 @ 2-Ohms RMS
225W x 2 @ 4-Ohms bridged RMS
ive seen birth sheets for both and they seem to each average 90-100W x 4 @ 4ohms.  which of these would give me more power if i use channels 3 and 4 to power a single subwoofer?
reference10.0
Member - Posts: 17
Posted: November 03, 2007 at 10:22 PM / IP Logged
the power line is under rated so you will get more rms than what is listed. check out this link it should help you decide. http://www.rockfordfosgate.com/products/amp_power_output.asp
