one gauge light
richard fry
Posted: October 30, 2007 at 6:50 AM / IP Logged
2007 chvey truck i added 1 gauge I would like to have a light that would dim what could i use for on& off switch with a dimmer that would be small the dash lights are controlled by mod our tec line said do try to tap in to the circuit thanks for any ideas Richard
js305
Member - Posts: 26
Posted: December 09, 2007 at 11:04 AM / IP Logged
I know you posted this a long time ago but if you are still checking back this is what I have done in the past. I find the wire that goes to the light in the radio and tap into that. A lot of times this is a single wire (orange in older Mopars). In most everything I have had this light comes on with the dash lights. This works for most older vehicles. Newer ones may present a different problem. In that case I would try and find other dash light circuits or maybe go into the fuse box and find a fuse that is labeled as such and tap into that wire.
Joe in Texas
