can relays work an audible alarm?
2confused
Posted: October 30, 2007 at 10:38 PM / IP Logged
My Jeep has a low fuel light. What I want to do is have, in addition to the light, an audible warning buzzer that when it sounds, I can use a push to silence switch to override the buzzer. Anyone know if this can be done using relays? If so, how? Thanks.
Platinum - Posts: 13,725
Posted: October 31, 2007 at 7:35 PM / IP Logged
You will need to get to the light bulb and verify that it is a 12 volt bulb.  If it is a 12 volt bulb you will need to get 1 wire to each side of the bulb and connect them to terminal 85 and 86 of the relay.  One wire to 85 and the other wire to 86.  This will energize the relay anytime the light bulb is lit.  Connect terminal 30 to a 12 volt power source, fused via a 5 amp fuse.  Terminal 87 will provide power to your buzzer or whatever you are using as an audible device.  Ground the ground wire of the audible device and you are set.
2confused
Posted: October 31, 2007 at 9:01 PM / IP Logged
Thanks for the input.  Figured someone out there would know!
becks2055
Posted: November 07, 2007 at 2:04 AM / IP Logged
how many times have you ran out of gas?can relays work an audible alarm? - Last Post -- posted image.
