2001 Chevy S10 Accessory wire question
TheSouthernDand
Member - Posts: 6
Posted: February 21, 2003 at 9:10 PM / IP Logged
Im trying to install a remote starter in my 2001 Chevy S10 truck and I am a little confused by which one of two wires is the accessory power wire. There is a heavy brown and a heavy orange wire that are both powered when the car is running. I am assuming from all the diagrams that I have looked at that they are both accessory wires. If my assumption is correct do I have to power both at remote start time?
By they way this site is great, lot of info.
TSD
mobiletoys2002
Gold - Posts: 1,050
Posted: February 21, 2003 at 9:28 PM / IP Logged
from what i remeber there is a white and a pink these are -ignition is pink and white is second ignition. a second ignition tests like an ignition wire an accesory wire loses power while cranking an ignition wire stays around 12 volts while cranking.
themagicone
Silver - Posts: 325
Posted: February 21, 2003 at 9:38 PM / IP Logged
u only need the orange acc wire, the brown is for some non needed acc durn remote start, hook it up if you want
TheSouthernDand
Member - Posts: 6
Posted: February 22, 2003 at 8:28 AM / IP Logged
Thanks for the replies. Very helpful.
TSD
