881 xp remote start
tx_f150
Posted: November 08, 2007 at 2:18 PM / IP Logged
I have a ford f150 and installed a python 881xp and everything works fine but the remote start feature shuts down if key is not inserted within 10 seconds I think i need to connect it to tach wire but not sure.
profuse007
Gold - Posts: 2,015
Posted: November 08, 2007 at 2:32 PM / IP Logged
yr of f150?
if 97+ did you use a bypass?
Houston,TX
tx_f150
Posted: November 08, 2007 at 3:18 PM / IP Logged
Sorry it is 2004 and yes I used a 556uw bypass from directed electronics. The truck starts fine and stays on for 10 seconds. Thank you for your quick response
profuse007
Gold - Posts: 2,015
Posted: November 08, 2007 at 3:22 PM / IP Logged
What wire did you use to trigger the 556U?
key inserted but no turning, right?
Houston,TX
JWorm
Platinum - Posts: 2,208
Posted: November 08, 2007 at 5:11 PM / IP Logged
What wire on the truck did you use for a tach signal?
tx_f150
Posted: November 08, 2007 at 5:44 PM / IP Logged
I used the blue negative trigger on the 556u to the blue negative trigger from the alarm and I did not use the tach since I was hoping the voltage sense would do the trick.
JWorm
Posted: November 08, 2007 at 6:28 PM / IP Logged
Voltage sense is very unreliable on those trucks. Use a fuel injector wire for a tach signal.
tx_f150
Posted: November 08, 2007 at 7:10 PM / IP Logged
Thanks I will give that a try
