2007 Mitsubishi Eclipse Alarm/Remote Start/Stereo Wiring
wiretapper
Copper - Posts: 166
Posted: November 14, 2007 at 12:50 PM / IP Logged
Anyone know if the '07 Eclipse is the same as the '06? I can't find a diagram on the '07, only the '06 model.
Twelvoltz
Platinum - Posts: 2,384
Posted: November 14, 2007 at 1:43 PM / IP Logged
Audiovox lists:
          #513451: 2007 MITSUBISHI ECLIPSE 2DR COUPE WITH AMPLIFIED AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / WHITE          (+)          RADIO HARNESS
     Accesory          BLUE          (+)          RADIO HARNESS
     Ground
               THIS VEHICLE GROUND THROUGH THE RADIO CHASSIS
     Illumination          GREEN / WHITE          (+)          RADIO HARNESS
               4
     Power Antenna          PINK          (+)          RADIO HARNESS
               3
     Amp Turn On
               THIS VEHICLE USES DATA FOR THE AMPLIFIER TURN ON
     LR Speaker (+)          YELLOW/BLUE
               THESE SPEAKERS ARE POWERED BY THE RADIO, FOR SPEAKERS POWERED BY THE AMPLIFIER SEE AMPLIFIER INFORMATION
     LR Speaker (-)          GRAY/BLUE
     RR Speaker (+)          YELLOW /GREEN
     RR Speaker (-)          WHITE
     Amp Location          BEHIND GLOVEBOX HIGH IN PASSENGER KICKPANEL
               THE AMPLIFIER POWERS THE FRONT DOORS AS WELL AS THE SUBWOOFER
     Steering Cntrls          OPTIONAL
     Radio Security          YES
     Security
     Battery          BLUE / YELLOW          (+)          IGNITION SWITCH HARNESS
     Ignition 1          RED          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger
               USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE
     Domelight Super          GREEN/ ORANGE          (-)          AT VEHICLE FUSE BOX
     LF Latch          LIGHT GREEN          (-)          AT VEHICLE FUSE BOX
     RF Latch          YELLOW          (-)          IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE
               ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE IS PART OF THE VEHICLE FUSE BOX
     Trunk Trigger          RED / YELLOW          (-)          IN HARNESS IN DRIVER KICKPANEL
               ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX
     Alarm Disarm          RED / GREEN          (-)          IN HARNESS IN DRIVER KICKPANEL
               ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX, THIS WIRE WILL ALSO UNLOCK THE DOORS WITH A DOUBLE PULSE
     Alarm Arm          LIGHT GREEN/ BLACK          (-)          IN HARNESS IN DRIVER KICKPANEL
               ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX, THIS WIRE WILL ALSO LOCK THE DOORS
     Parking Lights          GREEN / WHITE          (+)          AT VEHICLE FUSE BOX
     Convenience
     Headlights-Lo          ORANGE / BLUE & WHITE/ RED          (+)          AT EACH HEADLIGHT
     All Hazrd Lights          GREEN/ YELLOW          (-)          AT HAZARD SWITCH
     Wipers-Lo          BLUE/ORANGE          (+)          AT VEHICLE WIPER MOTOR
     Wipers-Hi          BLUE/RED          (+)          AT VEHICLE WIPER MOTOR
     Parking Brake          YELLOW /GREEN          (-)          AT PARKING BRAKE SWITCH
     Trnk Release          WHITE          (REV)          IN HARNESS IN DRIVER KICKPANEL
     Remote Start
     Accessory 1          BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BLUE/BLACK          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLUE/RED          (OPEN)          IGNITION SWITCH HARNESS
               WIRE RESTS AT (-) UNTIL KEY IS PUT IN IGNITION
     Tachometer          YELLOW/BLUE          (AC)          AT FUEL INJECTOR #1
               ALSO YELLOW/RED AT INJECTOR #2
     Speed Sense          YELLOW/BLACK          (AC)          AT POWERTRAIN CONTROL MODULE
               POWERTRAIN CONTROL MODULE IS LOCATED IN THE FRONT OF THE ENGINE COMPARTMENT ON THE DRIVER SIDE
     Brake Lights          GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED / BLUE          (+)          IN HARNESS IN DRIVER KICKPANEL
     Horn          LIGHT GREEN          (-)          IN HARNESS AT STEERING COLUMN
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          LIGHT GREEN/ RED          (-)          IN HARNESS IN DRIVER KICKPANEL
     PowerLock          VIOLET OR VIOLET/WHITE          (-)          IN HARNESS IN DRIVER KICKPANEL
               ALSO LOCATED IN ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE THAT IS PART OF THE FUSE BOX, WIRE IS VIOLET/WHITE AT ELECTRONIC TIME & ALARM CONTROL SYSTEM MODULE
     Driver Mtr Unlock          BLUE/BLACK          (REV)          AT VEHICLE FUSE BOX
     Driver Mtr Lock          BLUE/RED          (REV)          AT VEHICLE FUSE BOX
     Sunroof Open          GREEN/ RED          (-)          AT SUNROOF CONTROL SWITCH
     Sunroof Close          GREEN/ YELLOW          (-)          AT SUNROOF CONTROL SWITCH
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
wiretapper
Copper - Posts: 166
Posted: November 14, 2007 at 2:14 PM / IP Logged
Thanks! I'll check it against the info I already have to see if there's any difference.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
