03 impala rear defrost info needed
mennitti
Copper - Posts: 55
Posted: November 15, 2007 at 5:30 AM / IP Logged
Anyone have info on the wire color of an 03 Impala's rear defrost and what the resistance is?
Thanks.
Bnluis
Silver - Posts: 578
Posted: November 15, 2007 at 12:00 PM / IP Logged
White wire locate behind the HVAC sistem wich is basiclly yhe heat controls that wire runs to a relay that energizes the rear defogger as well as heated mirrors if the car is equipped. The wire need a negative latch ground to activate the relay.( ground all the time the remote starter is running.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
mennitti
Copper - Posts: 55
Posted: November 15, 2007 at 12:35 PM / IP Logged
Thank you.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
