04 toyota mr2 spyder brake r/s
kassdog
Copper - Posts: 257
Posted: November 18, 2007 at 1:19 PM / IP Logged
So I just tested the wires again and found out RED / white is a switch 12v wire with ignition and that RED / blue turns 12v with ignition and drops to 0 when pressed. Now im sure thats where I need to hook up the relay but I'm having a brain fart and can't figure it out.
techman93
Silver - Posts: 591
Posted: November 18, 2007 at 1:59 PM / IP Logged
so the RED / blue wire turns negative or to nothing? If it goes to ground then wire relay as follows:
pin 30 to ground
pin 87 to RED / blue wire
pin 86 fused 12v+
pin 85 negative trigger crank, or a negative while running out
if it rests at nothing then cut the RED / blue wire and connect pin 87a to side at switch and 87 away from switch.
Connect the brake wire from remote start as normal
I hope this helps.
P.S. Did you wire a transponder bypass for the anti theft?
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
kassdog
Copper - Posts: 257
Posted: November 18, 2007 at 2:07 PM / IP Logged
I'll try that right now. For now I'm just testing it with the key in the ignition to make sure I can get it.
kassdog
Copper - Posts: 257
Posted: November 18, 2007 at 2:41 PM / IP Logged
Allright it worked. Thanks for all the help guys. Its really wierd that dei didn't have anything on this.
techman93
Silver - Posts: 591
Posted: November 18, 2007 at 3:22 PM / IP Logged
sometimes other installers put together can help with weird issues like that. I am glad you got it working.
