remote start in a 07 chevy equinox ls
reecegr
Member - Posts: 28
Posted: November 24, 2007 at 5:51 PM / IP Logged
and thankyou
Platinum - Posts: 12,488
Posted: November 24, 2007 at 10:11 PM / IP Logged
Same as the 2006 Equinox. Do a search and you will find the information.
vitrox
Copper - Posts: 96
Posted: November 27, 2007 at 5:17 PM / IP Logged
they changed the equinox in 07. its totally different.
reecegr
Member - Posts: 28
Posted: November 27, 2007 at 6:50 PM / IP Logged
thanks for your replys,but Im still not sure,guess i'll go in blind thanks again.remote start in a 07 chevy equinox ls - Last Post -- posted image.
reecegr
Member - Posts: 28
Posted: December 01, 2007 at 7:38 AM / IP Logged
anyone else?
tedmond
Gold - Posts: 4,610
Posted: December 01, 2007 at 8:22 AM / IP Logged
i can confirm they changed th wires around alot. theres a PDF i included, Audiovox lists in the PDF, remember, always test your wires with a DMM
#510307: 2007 CHEVROLET EQUINOX 4DR SUV WITH 3.4L ENGINE AND AMPLIFIED AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED / WHITE (+) RADIO HARNESS
Accesory
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
Ground BLACK/ WHITE (-) RADIO HARNESS
Power Antenna WHITE (+) RADIO HARNESS
Amp Turn On DARK GREEN (DATA) RADIO HARNESS
THIS VEHICLE USES THAT LAN DATA NETWORK TO CONTROL AMPLIFIER TURN-ON
LF Speaker (+) TAN
THESE WIRES PROVIDE THE AUDIO SIGNAL TO THE AMPLIFIER
LF Speaker (-) GRAY
RF Speaker (+) TAN
RF Speaker (-) TAN/WHITE
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location BEHIND SUBWOOFER ASSEMBLY IN RIGHT REAR QUARTERPANEL
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN
APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER
FUNCTION OF THIS EQUIPMENT.
Speed Cntrl YES
Radio Security YES
Security
Battery RED / WHITE (2A) (+) IGNITION SWITCH HARNESS
WHEN DOING REMOTE START YOU MUST GET POWER AT THE BATTERY, OR FUSE BOX .
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Starter 1
THERE IS NO STARTER WIRE. WHEN THE BROWN ACCESSORY WIRE LOSES VOLTAGE, THE CAR
WILL CRANK.
Domelight Super WHITE (-) AT BCM MODULE UNDER RADIO IN DASH
LF Latch GRAY/BLACK (-) AT BCM MODULE UNDER RADIO IN DASH
RF Latch TAN/WHITE (-) AT BCM MODULE UNDER RADIO IN DASH
THIS WIRE IS COMON TO ALL OTHER DOORS
Trunk Trigger ORANGE / BLACK (-) AT BCM MODULE UNDER RADIO IN DASH
Hood Trigger PINK/BLACK (+) BCM BLACK CONN. PIN 17
Alarm Disarm RF ONLY !!!!!!!!!!!!!!!!!!!!
OEM ALARM WILL DISARM WITH REMOTE START.
Audiovox Tech Services Page 1 of 3
http://techservices.audiovox.com/Print.aspx 12/1/2007
Alarm Arm RF ONLY !!!!!!!!!!!!!!!!!!!!
Parking Lights LIGHT BLUE (+) LARGE HARNESS LOW IN DRIVERS KICK
Low Crr Pk Lights LIGHT BLUE (-) AT BCM MODULE UNDER RADIO IN DASH
Convenience
Headlights-Lo DARK BLUE (-) AT BCM MODULE UNDER RADIO IN DASH
Headlights-Hi PINK (-) AT BCM MODULE UNDER RADIO IN DASH
Wipers-Lo DARK GREEN (+) AT VEHICLE WIPER CONTROL SWITCH
Wipers-Hi VIOLET (+) AT VEHICLE WIPER CONTROL SWITCH
Parking Brake LIGHT BLUE (-) AT VEHICLE PARKING BRAKE SWITCH
Remote Start
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
Accessory 2
YOU MUST POWER THESE DURING REMOTE START FOR PROPER CRANK FUNCTION.
Starter 1
WILL CRANK.
Anti-Theft Type PASSKEY III
Anti-Theft Descript TRANSPONDER
Key Sense WHITE (+) IGNITION SWITCH HARNESS
THIS WIRE IS REQUIRED FOR PROPER REMOTE START FUNCTIONALITY
Tachometer UNCOMMON COLOR (AC) ANY INJECTOR NOT PINK/BLACK
Speed Sense BROWN (AC) AT PCM MODULE NEAR VEHICLE BATTERY
Low Crr. Pk Lights LIGHT BLUE (-) AT BCM MODULE UNDER RADIO IN DASH
Brake Lights LT. BLUE (+) AT SWITCH ABOVE PEDAL
Reverse Lights LT. GREEN (+) BCM PINK CONN. PIN 2
Horn TAN (-) BCM BROWN CONN. PIN 18
Modules
WIRE LOCATION
Module 1 BCM - BELOW CENTER OF DASH IN FRONT OF CONSOLE
Doorlocks/Windows
Power Unlock LT. BLUE (+) AT BCM BELOW CENTER OF DASH IN FRONT
OF CONSOLE
BCM GREY PLUG PIN 9
PowerLock LT. GREEN (+) AT BCM BELOW CENTER OF DASH IN FRONT
OF CONSOLE
BCM GREY PLUG PIN 7
Driver Mtr Unlock TAN (+) DRIVERS KICK
Driver Mtr Lock GREY (+) DRIVERS KICK
Pas Mtr Unlock TAN (+) DRIVERS SILL PLATE
LF Window Up DARK BLUE (REV) AT VEHICLE WINDOW CONTROL SWITCHES
Audiovox Tech Services Page 2 of 3
LF Window Dn BROWN (REV) AT VEHICLE WINDOW CONTROL SWITCHES
RF Window Up DARK BLUE (REV) AT VEHICLE WINDOW CONTROL SWITCHES
RF Window Dn BROWN (REV) AT VEHICLE WINDOW CONTROL SWITCHES
LR Window Up DARK GREEN (REV) AT VEHICLE WINDOW CONTROL SWITCHES
LR Window Dn VIOLET (REV) AT VEHICLE WINDOW CONTROL SWITCHES
RR Window Up LIGHT GREEN (REV) AT VEHICLE WINDOW CONTROL SWITCHES
RR Window Dn VIOLET (REV) AT VEHICLE WINDOW CONTROL SWITCHES
Sunroof Open DARK GREEN & DARK
BLUE (CLOSED) SUNROOF CONTROL SWITCH
THESE WIRES WILL OPEN AND CLOSE THE SUNROOF WITH A CLOSED CIRCUIT BETWEEN THEM
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom
from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the
recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Audiovox Tech Services Page 3 of 3
tedmond
Gold - Posts: 4,610
Posted: December 01, 2007 at 8:37 AM / IP Logged
heres the actual PDF so its easier to see and print
http://www.4shared.com/file/30882214/b4ada587/2007_Chevrolet_Equinox.html
