08 Ford Escape Alarm/Remote Start Wiring
ksutton
Copper - Posts: 94
Posted: November 25, 2007 at 8:38 PM / IP Logged
does any one have any directec dei info on a 08 ford escape.
Twelvoltz
Platinum - Posts: 2,384
Posted: November 26, 2007 at 8:55 PM / IP Logged
Audiovox lists:
          #512266: 2008 FORD ESCAPE 4DR SUV
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Please select another category
     Security
     Battery          BLUE/RED          (+)          IGNITION SWITCH
     Ignition 1          WHITE/ ORANGE          (+)          IGNITION SWITCH
     Starter 1          BLUE/WHITE          (+)          IGNITION SWITCH
     All Door Trigger          GRAY/VIOLET          (+)          DRIVERS KICK PANEL
     Domelight Super          BROWN          (-)          DIMMER SWITCH
     Parking Lights          VIOLET/WHITE          (+)          DRIVERS KICK PANEL
               SMALLER PLUG IN D. KICK PANEL
     Low Crr Pk Lights          BLUE/GRAY          (-)          IGNITION SWITCH
               IF THE VEHICLE UIS EQUIPPED WITH AUTO LAMP USE MUST USE TWO RELAYS ONE ON PARKING LIGHTS AND THE OTHER ON HEADLAMPS. IF VEHICLE DOES NOT HAVE AUTOLAMPS THEN ONLY ONE RELAY IS REQUIRED AND THAT WILL BE ON JUST THE PARKING LIGH WIRE. SEE TECH TIP.
     Convenience
     Headlights-Lo          YELLOW/BLUE          (+)          HEADLIGHT SWITCH
     Trnk Release          BROWN / BLUE          (+)          REAR DRIVERS SILL PLATE
     Remote Start
     Accessory 1          VIOLET/GREEN          (+)          IGNITION SWITCH
     Key Sense          BLUE/GRAY          (+)          IGNITION SWITCH
     Speed Sense          PURPLE / ORANGE, 8000 PPM          (AC)          UNDER HOOD ON FIREWALL 3 CONNECTOR PCM MIDDLE CONN. POSITION 1
     Low Crr. Pk Lights          BLUE/GRAY          (-)          IGNITION SWITCH
     Brake Lights          GRAY/BROWN          (+)          LOCATED IN THE SJB (DRIVERS KICKPANEL)
     Horn          BROWN          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Module 1          SJB-SMART JUNCTION BOX LOCATED ION DRIVERS KICK PANEL
     Doorlocks/Windows
     Door Lock Circuit          3 WIRE NEG
     Power Unlock          YELLOW/VIOLET          (-)          DRIVERS KICKPANEL
     PowerLock          BLUE/GREEN          (-)          DRIVERS KICKPANEL
     Driver Mtr Unlock          BLUE/GREEN          (+)          DRIVERS KICKPANEL
     Driver Mtr Lock          GRAY/BROWN          (+)          DRIVERS KICKPANEL
     Pas Mtr Unlock          VIOLET/GRAY          (+)          REAR DRIVERS SILL PLATE
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Although you requested DEI's info, I can say that this information matches directechs.
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
