04 endeavor diagram for alarm/rs
Acrux
Posted: December 03, 2007 at 9:19 PM / IP Logged
Any help would be great!  thanks!!
Twelvoltz
Platinum - Posts: 2,384
Posted: December 05, 2007 at 7:32 PM / IP Logged
Audiovox lists:
          #202220: 2004 MITSUBISHI ENDEAVOR 4DR SUV
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          (RED / WHITE)          (+)          AT THE RADIO HARNESS
     Accesory          (BLUE)          (+)          AT THE RADIO HARNESS
     Ground
               THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
     Illumination          (GREEN / WHITE)          (+)          AT THE RADIO HARNESS
     Dimmer          BLACK / YELLOW          (+)          RADIO HARNESS
     Amp Turn On          (PINK)          (+)          AT THE RADIO HARNESS
     LF Speaker (+)          (WHITE/ BLUE)
               THESE WIRES ALSO GO TO THE FRON LEFT TWEETER
     LF Speaker (-)          (BLACK/ BLUE)
     RF Speaker (+)          (WHITE/ RED)
               THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
     RF Speaker (-)          (BLACK/ RED)
     LR Speaker (+)          (YELLOW/BLUE)
     LR Speaker (-)          (GRAY/BLUE)
     RR Speaker (+)          (YELLOW/BLUE)
     RR Speaker (-)          (GRAY/RED)
     Amp Location          THE AMP IS LOCATED ABOVE THE PASSENGERS KICK PANEL
     Steering Cntrls          NO
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          BLUE / YELLOW          (+)          IGNITION SWITCH HARNSESS
     Ignition 1          BLACK/ WHITE          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          RED / GREEN          (-)          AT THE ETACS ECU
               THE ALL DOOR TRIGGER IS ALSO LOCATED IN A 3 PIN PLUD ABOVE THE FUSES, PIN 1
     Domelight Super          RED / GREEN          (-)          AT KEYLESS ENTRY MODULE TO RIGHT OF FUSEBOX BEHIND DRIVERS SIDE OF DASH
     LF Latch          LIGHT GREEN          (-)          AT THE ETACS ECU
               THE DRIVERS LATCH IS ALSO LOCATED ABOVE THE FUSES IN A 15 PIN CONNECTOR. THE DRIVERS LATCH IS IN PIN 6.
     RF Latch          YELLOW          (-)          AT THE ETACS ECU
               THE DRIVERS REAR LATCH IS ALSO LOCATED ABOVE THE FUSES IN A 15 PIN CONNECTOR. THE DRIVERS LATCH IS IN PIN 10.
     LR Latch          ORANGE / BLACK          (-)          AT THE ETACS ECU
     RR Latch          ORANGE / BLACK          (-)          AT THE ETACS ECU
     Trunk Trigger          RED / YELLOW          (-)          AT THE ETACS ECU
               THE RED / YELLOW IS THE GLASS LATCH WIRE THE YELLOW/BLUE IS THE LIFTGATE LATCH WIRE BOTH WIRES ARE LOCATED AT THE ETACS ECU ATTACHED TO THE BACK OF THE FUSE BOX, PIN 37 AND 52.
     Hood Trigger          (BLUE/WHITE)          (-)          AT THE ETACS ECU, PIN 24
     Alarm Disarm          (RED / GREEN)          (-)          AT THE ETACS ECU, PIN 25
               PIN #25
     Alarm Arm          (LT. GREEN/ BLACK)          (-)          AT THE ETACS ECU, PIN 42
               PIN #42
     Parking Lights          (GREEN / WHITE)          (+)          AT THE PLUG ABOVE THE FUSES, PIN 2
     Convenience
     Headlights-Lo          (ORANGE / BLUE)          (-)          AT THE HEADLIGHT RELAY UNDER THE HOOD
     Headlights-Hi          (WHITE/ RED)          (-)          AT THE HEADLIGHT RELAY UNDER THE HOOD
     All Hazrd Lights          GREEN/ YELLOW           (-)          AT ETACS MODULE UNDER DRIVER SIDE DASH
     Wipers-Lo          (RED / BLACK)          (+)          AT THE WIPER MOTOR
     Wipers-Hi          (BLUE/RED)          (+)          AT THE WIPER MOTOR
     Parking Brake          (YELLOW /GREEN)          (-)          AT THE PARKING BRAKE SWITCH
     Remote Start
     Ignition 2          BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Accessory 1          BLUE/BLACK          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          TRANSPONDER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          (BLUE/RED)          (OPEN)          IGNITION SWITCH HARNESS
               THE KEY SENSE WIRE RESTS AT GROUND AND GOES OPEN WHEN YOU PUT THE KEY IN THE IGNITION.
     Tachometer          USE THE UNCOMMON WIRE AT COIL          (AC)          OR US THE UNCOMMON WIRE ATHE FUEL INJECTOR
     Speed Sense          BLACK/ BLUE          (AC)          AT ABS MODULE BEHIND PASSENGER STRUT TOWER
     Brake Lights          (GREEN)          (+)          AT THE BRAKE PEDAL SWITCH
     Reverse Lights          (RED / BLUE)          (+)          WHITE 16 PIN PLUG IN THE DRIVERS KICK PANEL
     Horn          (LT. GREEN)          (-)          AT THE ETACS ECU, PIN 44
               PIN #44
     Modules
     WIRE          LOCATION
     Module 1          ETACS ECU - LOCATED UNDER DRIVER'S SIDE DASH TO THE RIGHT OF FUSE BOX.
     Doorlocks/Windows
     Power Unlock          LIGHT GREEN/ RED          (-)          AT THE ETACS ECU
     PowerLock          VIOLET          (-)          AT THE ETACS ECU
     Driver Mtr Unlock          BLUE/BLACK          (REV)          AT THE ETACS ECU
     Driver Mtr Lock          BLUE/RED          (REV)          AT THE ETACS ECU
     Pas Mtr Unlock          BLUE/ORANGE          (REV)          AT THE ETACS ECU
     Pas Mtr Lock          BLUE/RED          (REV)          AT THE ETACS ECU
     LF Window Up          (RED / BLACK)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     LF Window Dn          (GREEN/ BLACK)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     RF Window Up          (RED / WHITE)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     RF Window Dn          (GREEN / WHITE)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     LR Window Up          (GREEN)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     LR Window Dn          (YELLOW)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     RR Window Up          (ORANGEA)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     RR Window Dn          (GREEN/ YELLOW)          (REV)          AT THE DRIVERS DOOR WINDOW SWITCH
     Sunroof Open          (BLUE/WHITE)          (REV)          AT THE SUNROOF SWITCH
     Sunroof Close          (BLUE/RED)          (REV)          AT THE SUNROOF SWITCH
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
