two ports into one
jmelton86
Gold - Posts: 1,228
Posted: December 11, 2007 at 8:12 PM / IP Logged
killa101, what exactly are you trying to do here?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
killa101
Copper - Posts: 53
Posted: December 11, 2007 at 10:36 PM / IP Logged
stevdart wrote:
I don't accept your last illustration as a proper vented enclosure.  It's a muddy mix between a single chamber and dual chamber and I wouldn't count on the port response accuracy.  My opinion is that a multi-driver single chamber enclosure must share airspace other than that which is comprised of port airspace.
That is what I was looking for. I was looking to put the port in the middle but I guess i might just put it in the side like the picture below.
two ports into one - Page 2 - Last Post -- posted image.
I would just have two seperate chambers but I'm getting some really long port lengths and I don't think i will be able to get it to work that way. Right now I'm getting like 50 inches for both of the ports. I don't like the idea of a single chamber but if that is what I have to do then that's ok.
DYohn
Platinum - Posts: 10,741
Posted: December 12, 2007 at 1:08 PM / IP Logged
Why use a slot port?  if you want your port(s) between the drivers, use round ports.
haemphyst
Platinum - Posts: 5,059
Posted: December 12, 2007 at 1:11 PM / IP Logged
Like I said:
haemphyst wrote:
You'll probably run out of box volume before you get enough line. Why not just build it per the plans?
DYohn
Posted: December 12, 2007 at 1:19 PM / IP Logged
If you must use a slot port and want it in the center, and it needs to be longer than the depth of the enclosure, you could design something like this:
And actually the segment in the middle can be a single wall...
stevdart
Platinum - Posts: 5,816
Posted: December 12, 2007 at 5:52 PM / IP Logged
Round ports, of course!  I guess I wasn't thinking outside of the box like DYohn is.    two ports into one - Page 2 - Last Post -- posted image.
killa101
Copper - Posts: 53
Posted: December 12, 2007 at 9:24 PM / IP Logged
I convinced myself i like my idea of putting the port on the side.
I would use the round ports but they still had to be bent because they were too long. Plus i have plenty of wood and nothing for round ports.
Thanks for your help guys.two ports into one - Page 2 - Last Post -- posted image.
