2003 lincoln aviator remote start
mbaudio06
Copper - Posts: 60
Posted: December 12, 2007 at 5:17 PM / IP Logged
I did a search and nothing came up for this particular vehicle. Can i possibly get a wiring diagram and also a list of possible bypass, door lock modules that  may use. Also any tips, or tricks for this vehicle will be greatly appreciated. THanks in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 12, 2007 at 8:19 PM / IP Logged
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Battery
 IGNITION RED / green Ignition switch harness   +
 ACCESSORY Gray / YELLOW Ignition switch harness   +
 STARTER Green Ignition switch harness   +
 KEY SENSE Lt.GREEN/ violet Ignition harness   +
 TACH SIGNAL Use an injector
 LOCK Pink / YELLOW In driver's door   -
 UNLOCK Pink/green In driver's door   -
 DOORPIN Blue/white At light under dash   +
 R.A.P. SHUT DOWN Yellow/black In driver's door   -
 This is the vehicle's doorpin wire. You must interrupt this wire with a relay to simulate the door opening. This with shut the radio and accessories.
 FACTORY ARM Yellow/black In driver's door   -
 This is the vehicle's doorpin wire. You must interrupt this wire with a relay to simulate the door opening. Trigger the relay at the same time as lock to arm the factory alarm.
 FACTORY DISARM Green In driver's door   -
 BRAKESWITCH Lt.green At switch above brake pedal   +
 PARKLIGHTS Brown At light switch harness   +
 There are 2 Brown wires, this is the larger of the 2.
 HORN Yellow/light blue At steering column   -
 VSS WIRE Gray/black Radio harness   AC
Bypass XKO4...or one like it!
