remote start for 04 pt cruiser
umfanec
Posted: December 13, 2007 at 4:25 PM / IP Logged
I need some help with installing a remote starter for a 2004 PT Cruiser.  What would help great is the PT's wiring diagram, or just what wires are what so I can install this remote starter.  It is an Autopage RS-600 if that helps.
tedmond
Gold - Posts: 4,610
Posted: December 13, 2007 at 5:36 PM / IP Logged
remote start for 04 pt cruiser - Last Post -- posted image.Battery PINK/BLACK & RED (+) IGNITION SWITCH HARNESS
remote start for 04 pt cruiser - Last Post -- posted image.Ignition 1 BLUE (+) IGNITION SWITCH HARNESS
remote start for 04 pt cruiser - Last Post -- posted image.Accessory 1 BLACK/ ORANGE (+) IGNITION SWITCH HARNESS
remote start for 04 pt cruiser - Last Post -- posted image.Accessory 2 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
remote start for 04 pt cruiser - Last Post -- posted image.Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
remote start for 04 pt cruiser - Last Post -- posted image.Anti-Theft Type DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
remote start for 04 pt cruiser - Last Post -- posted image.Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
remote start for 04 pt cruiser - Last Post -- posted image.Key Sense LIGHT BLUE (-) IGNITION SWITCH HARNESS
remote start for 04 pt cruiser - Last Post -- posted image.Tachometer BLACK/ GRAY (AC) IN GREY CONNECTOR AT THE PCM
remote start for 04 pt cruiser - Last Post -- posted image.Speed Sense WHITE/ ORANGE (AC) AT THE POWERTRAIN CONTROL MODULE
remote start for 04 pt cruiser - Last Post -- posted image.Parking Lights BLACK / YELLOW (+) AT THE HEADLIGHT SWITCH
remote start for 04 pt cruiser - Last Post -- posted image.Brake Lights WHITE/ TAN (+) DRIVER'S KICK PANEL remote start for 04 pt cruiser - Last Post -- posted image.
remote start for 04 pt cruiser - Last Post -- posted image.Reverse Lights VIOLET/BLACK
remote start for 04 pt cruiser - Last Post -- posted image.Horn BLACK/ RED (-) STEERING COLUMN HARNESS
umfanec
Posted: December 13, 2007 at 7:33 PM / IP Logged
tedmond    thanks for the info.
One other thing.  How do I know if it needs a bypass module or not?  If it needs a key where do I get that?
another-kelly
Silver - Posts: 618
Posted: December 13, 2007 at 11:08 PM / IP Logged
if the key is grey, it needs a bypass. if the key is black, it does not
must have 2 keys to program any additional keys on your own. if you only have one and need a second i suggest a GOOD locksmith or the dealership
racing_bidule
Copper - Posts: 66
Posted: December 13, 2007 at 11:37 PM / IP Logged
The PT Cruiser needs a bypass, it's a first generation Chrysler key...
Doorlocks are also multiplexed on this vehicle, if it's equipped with OEM alarm you may be considering a unit which does it all!
http://www.idatalink.com/store/viewDoc.php?id=104
There's many types of bypasses which fit on this vehicle, you should really make some shopping to avoid the multiple relays & resistors. :)
Have fun!
If you fail on your first attempt, at least destroy all evidence you tried!
umfanec
Posted: December 14, 2007 at 6:13 AM / IP Logged
It is not equipped with the OEM alarm.  It does have the power windows and door locks on it.  The unit I have can do remote start and power door locks.
umfanec
Posted: December 15, 2007 at 4:26 PM / IP Logged
the key is grey, so is there an aftermarket bypass module that I should get?
