wiring nightmare, 04 acura mdx
highmath
Member - Posts: 7
Posted: June 11, 2007 at 7:46 PM / IP Logged
Ok I am trying to put in a new keyless entry in my 04 Acura MDX because I refused to pay $500 to replace my defective, out of warranty, OEM system. So far to have got the unlock to work but not the lock. They are neg. pulse locks. I upload a pic of the wire harness diagram. Can anyone make sense to it so I can finish. I stumped. Thankswiring nightmare, 04 acura mdx -- posted image.
flobee4
Silver - Posts: 585
Posted: June 11, 2007 at 8:08 PM / IP Logged
Ok here you go,
Orange and ORANGE / black  -  Don't use
Yellow and yellow/black  - Ground
White - goes to car's unlock wire - blue/orange in passanger side fuse panel top green plug.
WHITE/ black - goes to car's unlock wire - BLACK/ orange in the same plug as above.
here is a web site that has your wireing guide with pictures.  it also shows your disarm wire if your car has a factory alarm as well.  If you need help with that let us know
http://64.85.6.121/diagrams/diagram.asp?ModelID=19707&MakeID=6&link=BULLDOG
Also, if you do need to run a disarm wire into the drivers door because your car has a factory alarm - read this how to:
https://www.the12volt.com/installbay/forum_posts.asp~TID~78731~PN~1
highmath
Member - Posts: 7
Posted: June 11, 2007 at 9:27 PM / IP Logged
Thanks a lot.  I'll try this out and let you know of the outcome!
highmath
Member - Posts: 7
Posted: June 13, 2007 at 9:25 PM / IP Logged
Well I got the system installed and it works great. Now for the factory alarm. Now I know the location of the factory alarm, arm and disarm wire, is in the door. Is it as simple to run a wire from the arm wire spliced into the lock wire from the system and visa versa for the disarm/unlock or is there more to it? Do I need to fuse the connections?
imseth85
Copper - Posts: 71
Posted: June 13, 2007 at 10:26 PM / IP Logged
first figure out if you even need to.....try locking the car with the remote and waiting about a minute. Leave the drivers window rolled down...now reach in and open the car. If the horn honks repeatedly it means it was successfully armed. Now lock the car again (with the remote), leave it for a minute, and then unlock it with the remote and open the door. If the horn does not sound you do not need to bother with those wires.
Seth Alvo     NY
Mobile Electronics Installer
flobee4
Silver - Posts: 585
Posted: June 13, 2007 at 11:00 PM / IP Logged
if you do have a factory alarm, you will need to run 2 wires into the door.  1 to arm and 1 to disarm.
arm - blue/white, pin 6 - in drivers door(power window switch)
disarm -   BLACK/ red to blue, pin 16 - same location as above
To test if you have a factory alarm on that car:
1) Open drivers side window
2) Close door and lock the doors using the key cylinder on the outside of the drivers door.
3) Wait about a minute
4) reach inside the car window and unlock the door from the inside and open the door
5) If an alarm goes off, you have an alarm. If not, you don't have to worry about the wires inside the door and you aregood to go.
highmath
Member - Posts: 7
Posted: June 13, 2007 at 11:04 PM / IP Logged
I tried that. The security light at the door doesn't blink, nor when I lock the car with the system and open the door through the window, does the alarm sound.
highmath
Member - Posts: 7
Posted: June 13, 2007 at 11:17 PM / IP Logged
...and I splice these wires into the respective lock/unlock wires of my system? Do I need to fuse them?
highmath
Member - Posts: 7
Posted: June 13, 2007 at 11:20 PM / IP Logged
sorry, yes I know that I have a factory alarm.
flobee4
Silver - Posts: 585
Posted: June 14, 2007 at 12:22 AM / IP Logged
well, 2 things.
1st you do not need to fuse them.
2nd you can split up your door lock wires, but you will need to diode isolate each wire.  this means 2 diodes for lock, 2 for unlock. the white bands on the diode need to face the keyless entry module for a 4 diodes.
Thursday, January 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
