98 accord disarm wire
profuse007
Gold - Posts: 2,015
Posted: January 17, 2003 at 8:07 PM / IP Logged
where is the disarm wire for this car. i heard it's in the driver door. i checked out and i assume it runs from the door key hole. there, i found three wire, are these the wires. if so which wire is it.
profuse007
Gold - Posts: 2,015
Posted: January 17, 2003 at 8:13 PM / IP Logged
am installing viper 790xv, the disarm wire output  shows (-) on the viper reference and it say to use a relay. is the accord a neg disarm or positive disarm? if it is neg disarm for the accord, do i need a relay.
ViperATC5
Copper - Posts: 202
Posted: January 17, 2003 at 10:59 PM / IP Logged
To disarm factory security, find the blue wire and supply it with a negative pulse : On the EX the wire is located at the drivers power window switch, on the LX the wire is at the keyless/security unit which is attached to the drivers underdash panel - use a relay as instructed
Chris Luongo
Platinum - Posts: 3,746
Posted: January 19, 2003 at 8:13 PM / IP Logged
I usually just set up my unit to unlock the doors before remote start, and then re-lock them right afterward; this is easier than going into the door.
profuse007
Gold - Posts: 2,015
Posted: January 19, 2003 at 10:59 PM / IP Logged
i still cant seem to find the disarm wire. there is blue wire at this plug coming out of inside the door and this guide say that it is at e power window switch. i dont know which one. please help me.
ViperATC5
Copper - Posts: 202
Posted: January 19, 2003 at 11:28 PM / IP Logged
use a DMM to test and see if that wire gets a negative pulse when you disarm the factory alarm
profuse007
Gold - Posts: 2,015
Posted: January 19, 2003 at 11:41 PM / IP Logged
am sorry to ask you but what is DMM test, am not much of a electronic wiz. i got every to work so far but the arm goes off when i remote start. this is probably the last wire i need
Chris Luongo
Posted: January 20, 2003 at 6:48 AM / IP Logged
If you're just tying into wires at random, you shouldn't be installing.  A DMM (digital multi-meter) will come with basic instructions on how to use it, or you can probably find more information by searching around this site.
profuse007
Gold - Posts: 2,015
Posted: January 20, 2003 at 7:28 AM / IP Logged
thanks. i do use that
Auto_Obsessions
Member - Posts: 25
Posted: January 20, 2003 at 5:08 PM / IP Logged
The best way to find the wire is to just go into the driver door. Look for where the key cylinder is and find the wires coming from there. When you turn the key to unlock the door the wire will show negative.
Page of 3
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
