Gentex Mirror Wiring Diagram
unbwogable
Posted: May 11, 2004 at 4:29 PM / IP Logged
I have a Gentex with 5 pins, no harness. Any suggestions? I'm going to attempt to use the info already provided on this forum. Wish me luck all... If I blow this sucker up I'll post some links to pictures..
-Bryan
rrrfoma
Posted: June 25, 2004 at 11:14 PM / IP Logged
Hi,
Does anybody know if it is possible to re-use an existing vehicle t-probe for Gentex mirror?
What modifications are required (I assume resistance must be changed) ?
What are original Genex t-probe parameters?
I fogot to mention - I'm using GNTX-261 and GNTX-177.
Thanks in advance!
rboc
Posted: July 15, 2004 at 12:14 PM / IP Logged
Gentleman wrote:
The Gentex mirror I had seemed diffrent from what you are describing, it did not have the autoheadlight feature, it had 7 pins but only 5 wires as such:
1 Dark Blue    12V + Ignition
2 black        Ground
3 Violet       Back Up Lamp Connection
4 White        Side View Mirror +
5 Yellow       Side Vie Mirror -
4&5 were used to control side view mirrors that had a dimming feature.
Sorry I could not help
rboc
Posted: July 15, 2004 at 12:20 PM / IP Logged
I got a Gentex-120 from a '97 Cadillac STS.  Mine came with a separate "black box" that was fastened to the windshield with double face tape (factory stuff).  When I hook power and ground, I get the mirror to work, but the compass is stuck on N.  Is the extra box part of the compass?
Does anyone know the proper wiring to connect these two devices?
Thanks for any help you can provide!
Robin Masters
Posted: July 21, 2004 at 2:25 AM / IP Logged
Try to calibrate it, if the problem persist maybe the "compass module" is damaged, the separate "extra box" is not a part of the mirror,  but I don´t known how it works.
Sorry for the spelling but my English is not good. if you have more questions maybe I can help you.
Gentex Mirror Wiring Diagram - Page 7 -- posted image.
backinblack_gp
Member - Posts: 21
Posted: July 21, 2004 at 5:21 PM / IP Logged
Just to add some helpful wiring info for here...
(Chrysler) Gentex GNTX-101 Mirror wiring: (From left to right as you face the back of the mirror)
WHT/RED - +12vdc accessory input
BLK - Chassis ground
BLU/BLK - +12vdc reverse lamps input.  (Ground if not using)
Here is the mirror in question:
backinblack_gp
Member - Posts: 21
Posted: July 21, 2004 at 5:26 PM / IP Logged
Now, I also have a Chrysler GNTX-104 with no wiring info...
The 2-pin temp probe connector is shown to the right under the plastic cover.  This unit apparently utilizes 2 foreward facing photoresistors to enable the high-beam disable function which I would like to use.
Does anyone have the wiring information for this one???
Thanks!
backinblack_gp
Member - Posts: 21
Posted: July 21, 2004 at 8:05 PM / IP Logged
I didn't see the GNTX-126 listed, but here's what I know about it...
General Motors wiring as read from left to right while looking at the back of the unit:
BRN - +12vdc accy
GRN - +12vdc reverse light input
GRY - (Unknown)
PNK - (Unknown)
backinblack_gp
Member - Posts: 21
Posted: July 23, 2004 at 5:41 PM / IP Logged
Update on the GNTX-126...
GRY = +Output to side dimming mirror
PNK = -Output to side dimming mirror
Update on the GNTX-104 pictured a few posts ago:
WHT/RED = Accessory +12vdc
PNK = Constant +12vdc
BLK = Ground
VIO/BLK = +12vdc reverse inhibit input
ORG/WHT = Active low transistor output from auto headlights function
BRN = Second active low transistor output from auto headlights function
Hopefully others can benefit from this information.
rasal
Posted: July 25, 2004 at 2:52 PM / IP Logged
I recently purchased a gntx-177 mirror supposedly from a GM product.  The wiring harness was cut but the wires from the mirror are red, black, white, blank, blank, light green and light green.  The mirror is auto dimming, temp and compass.  I also need the wiring harness and temperature sensor.  Any assistance on wiring and obtaining parts is appreciated.
rasal
Page of 8
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
