2007hyundai accent, remote start wiring
speedbro
Posted: December 17, 2007 at 7:35 PM / IP Logged
Hi, I need the wiring diagram to install a remote starter in a 2007 hyundai accent sedan base model with manual transmission
and do you know if it got a tranponder key?
thanks
Boris
mikvot
Gold - Posts: 1,043
Posted: December 17, 2007 at 7:43 PM / IP Logged
According to my notes, there is no transponder.
Wire/Function Colour Location/Description Polarity
 12 VOLTS Green Ignition switch harness   +
 IGNITION Pink Ignition switch harness   +
 ACCESSORY Orange Ignition switch harness   +
 ACCESSORY 2 Yellow Ignition switch harness   +
 STARTER White Ignition switch harness   +
 KEY SENSE Blue Ignition switch harness   +
 TACH SIGNAL Green In large white plug on left side fo fusebox   AC
 FUEL INJECTOR Opposite from Brown At any injector on engine   AC
 LOCK Yellow In 24-pin plug on BCM at right of steering column   -
 UNLOCK Yellow/black In 24-pin plug on BCM at right of steering column   -
 DOORPIN Green In 20-pin plug on BCM at right of steering column   -
 HOODPIN Brown In 20-pin plug on BCM at right of steering column   -
 TRUNK PIN GREEN/ orange In 20-pin plug on BCM at right of steering column   -
 FACTORY ARM Yellow/orange In 20-pin plug on BCM at right of steering column   -
 FACTORY DISARM WHITE/ black In 20-pin plug on BCM at right of steering column   -
 BRAKESWITCH Green At switch above brake pedal   +
 PARKLIGHTS (-) Red In 20-pin plug on BCM at right of steering column   -
 HAND BRAKE GREEN/ orange At switch on handbrake lever   -
 HORN Blue At steering column   -
 REVERSE LIGHTS WHITE/ black Low in driver's kickpanel   +
