Kenwood+Honda Accord 96
BuccKevin
Posted: May 28, 2002 at 7:46 PM / IP Logged
OK I bought a cd player off ebay for $200... When I received it, it did not power up when I connected the wires... I just want to know if my wiring is incorrect or did this mofo sold me a busted cd player which i cannot return because he won't reply to my email!!! anyways... the kenwood wire diagram are as follow:
· RED: Switched Power
· BLACK: Chassis Ground
· YELLOW: Constant Power
· BLUE: Remote Turn on / Power Antenna Lead
· ORANGE: Dimmer
· WHITE and WHITE/ BLACK: Left Front
· GRAY and GRAY/BLACK: Right Front
· PURPLE and PURPLE / BLACK: Right Rear
· GREEN and GREEN/ BLACK: Left Rear
Here's my car harness.....
Memory : YEL/WHT
Ignition Pwr : WHT/RED
Ground : BLK
Illumination : RED / BLK
Power Ant. : YEL/WHT
  Front Speakers *
Kit : FACTORY GRILL
RF(+) : RED / GRN
RF(-) : BRN/BLK
LF(+) : BLU/GRN
LF(-) : GRY/BLK
  Rear Speakers *
Kit : FACTORY GRILL
RR(+) : RED / YEL
RR(-) : BRN/WHT
LR(+) : BLU/YEL
LR(-) : GRY/WHT
Now these are the wires I connected together..
Kenwood Wire                                     Honda Wire
RED: Switched Power          Ignition Pwr : WHT/RED
BLACK: Chassis Ground      Ground : BLK
YELLOW: Constant Power   Memory/Constant : YEL/WHT
BLUE: Power Antenna        Power Ant. : YEL/WHT
Speaker wires were not connected because I was just testing for power...Do I need to connect the speaker wires for it to power up? Probably not...So this thing should be working with these wire connections correct? Busted cd player or miss wiring?
bberman1
Gold - Posts: 2,314
Posted: May 28, 2002 at 8:11 PM / IP Logged
Your wire diagram looks good. But are you sure you are not confusing the constant and antenna trigger. They are both yellow/white. You can test the head unit by taking it out of the car. Wire the constant and switched wire together. Hook the constant/switched to the positive side on the battery. Hook up the ground to the negative side of the battery. If the unit powers up then it works if it doesn’t then you could have a bad head. Also try to check the fuses on the back of the head unit.
BuccKevin
Posted: May 28, 2002 at 8:36 PM / IP Logged
yeah i'm pretty sure it's the constant.. I checked it  with a voltimeter....hmmm...
Platinum - Posts: 12,488
Posted: May 29, 2002 at 8:52 AM / IP Logged
The deck should power up if you add 12 volts to the wire in pin # 5 ( Constant ) , pin # 4 ( Ignition ) and add ground to pin # 11. If you did this and nothing is working, check the fuse on the back of the deck like bberman1 said. Otherwise you better give this mofo some bad feedback.... seems that the wiring is OK with me.Kenwood+Honda Accord 96 -- posted image.
